![]() | Home > Puma (Tdci) > Driving a Puma smoothly |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
mine 2.4 wasnt great when new but the gear change mechanism mod improved it no end, I have a replacement clutch and IRB remap.
I also generally now start off in 2nd gear as 1st is just a waste of time (unless towing the caravan or starting facing up hill). I removed driveline play with Ashcroft adaptor shaft, ATB diffs and 1 piece rear drive shafts and it drove very well, gear change and clutch action equally as good as my VW up, however I now have some slack reappearing and have adjusted to taking up the play before fully engaging the clutch. These gearboxes can have a really nice change mine has at any engine revs but only since the other things were done, my feeling is that its the other bits around them effect it badly. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8448 ![]() ![]() ![]() |
i have a 2.4 2010 110 with 117k and its as smooth as
i have a 2011 130 now m57 auto but prior to that was a 2.4 79k miles nightmare to make smooth both vehicles have aschroft everything; cvs, shafts, dms, diffs, rebuilt centre diffs and output shafts. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3439 ![]() ![]() |
l'll have a look at the front drive members but in my experience they're usually okay due to oil leaking from the front differential, which lubricates them.
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 274 ![]() ![]() ![]() |
To add to LR90XS2011‘s list, also make sure your front axles are shimmed properly.
The main problem seems to be, that if your foot is on the clutch then the engine response is very on/off or prone to jerkiness.
So if you approach a junction in third gear, you change down to second and feed the clutch back in as you accelerate, and it starts kangarooing. The only way to avoid it is to be quick on the clutch but then you can get a lurch as the drive engages, resulting in more kangarooing. Alive (the nearest recommended tuner to me) say they can map a lot of this out by softening the throttle response at lower RPM. l guess l will have to give it a try. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3633 ![]() ![]() ![]() |
Following my earlier comment, I checked my clutch switch, 2.2 engine, unsure if the switch is the original, as master cyl was replaced in previous ownership - but my clutch switch is normally open, and is closed when I start pressurizing the clutch hydraulic system. My switch is then opposite to comment by Martin on https://www.defender2.net/forum/topic65199.html Perhaps there is a difference 2.2 to 2.4? So also the engine response when I tested with the clutch switch connector disconnected and left open and shorted make sense. During normal driving the engine rpms drop and rise slower so as not to shock the transmission. I think it is worth checking how your clutch switch operates as I do think that it contributes to a big chunk of the Puma drivability. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17990 ![]() ![]() ![]() |
2.2 is NO, 2.4 is NC. They are different due to the different ECMs.
Lightning, do you know anyone local with a Puma you could drive and who you could let drive yours? Either your vehicle or technique is causing problems and that would be the easiest way to diagnose which.it is. |
Thanks BW.
Perhaps your clutch bite point and switch switching point are out of sync. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Possibly.
l've noticed that looking at clutch switches, most Ebay sellers are listing them as suitable for "TD5/Puma" This is almost certainly not the case. The TD5 one operates the opposite way round. l found this out when l had my Defender TD5. One is normally open and the other is normally closed. This could cause all kinds of issues. As it did on my TD5 as l was sold a Puma one. |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2307 ![]() ![]() ![]() |
as mentioned above I had some jerky issues and tried bridging switch, etc (actually made it worse) and in the end simply replaced with a new Genuine LR switch (wasn't any great cost) and its a different drive........
no codes or anything else to suggest it wasn't working |
