Home > Puma (Tdci) > Driving a Puma smoothly
Page 2 of 3 <123>
LR90XS2011
mine 2.4 wasnt great when new but the gear change mechanism mod improved it no end, I have a replacement clutch and IRB remap.
I also generally now start off in 2nd gear as 1st is just a waste of time (unless towing the caravan or starting facing up hill).
I removed driveline play with Ashcroft adaptor shaft, ATB diffs and 1 piece rear drive shafts and it drove very well, gear change and clutch action equally as good as my VW up, however I now have some slack reappearing and have adjusted to taking up the play before fully engaging the clutch.
These gearboxes can have a really nice change mine has at any engine revs but only since the other things were done, my feeling is that its the other bits around them effect it badly. DEFENDER 90 TDCI XS,
Post #1076682 2nd Oct 2025 7:22am
lightning
l've looked at probably thirty Defenders over the last three years and there were two that stood out. One was a very low mileage one and the other, had done 117,000 but the seller had just fitted a new clutch and output shaft.
Both were absolutely lovely to drive with none of the above issues. So l know it's possible to improve one.
How long it stays like that after the new clutch is fitted, who knows. l've driven a 30,000 miles one that was awful.
Post #1076683 2nd Oct 2025 7:28am
jst
i have a 2.4 2010 110 with 117k and its as smooth as
i have a 2011 130 now m57 auto but prior to that was a 2.4 79k miles nightmare to make smooth
both vehicles have aschroft everything; cvs, shafts, dms, diffs, rebuilt centre diffs and output shafts. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076701 2nd Oct 2025 10:37am
lightning
l'll have a look at the front drive members but in my experience they're usually okay due to oil leaking from the front differential, which lubricates them.
Post #1076706 2nd Oct 2025 11:31am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
To add to LR90XS2011‘s list, also make sure your front axles are shimmed properly.
Post #1076768 3rd Oct 2025 5:14am
lightning
The main problem seems to be, that if your foot is on the clutch then the engine response is very on/off or prone to jerkiness.
So if you approach a junction in third gear, you change down to second and feed the clutch back in as you accelerate, and it starts kangarooing.
The only way to avoid it is to be quick on the clutch but then you can get a lurch as the drive engages, resulting in more kangarooing.
Alive (the nearest recommended tuner to me) say they can map a lot of this out by softening the throttle response at lower RPM.
l guess l will have to give it a try.
Post #1076801 3rd Oct 2025 2:26pm
Dinnu
Dinnu wrote:
With clutch switch disconnected - the engine maintained very high revs between gear changes. Throttle response was normal. I suspect that this would be the state of the switch when your foot is off the clutch.
With clutch switch shorted - the engine rpm dropped very quickly, faster than when clutch switch was connected, but throttle response became too sharp and led to kangarooing.
Following my earlier comment, I checked my clutch switch, 2.2 engine, unsure if the switch is the original, as master cyl was replaced in previous ownership - but my clutch switch is normally open, and is closed when I start pressurizing the clutch hydraulic system.
My switch is then opposite to comment by Martin on https://www.defender2.net/forum/topic65199.html
Perhaps there is a difference 2.2 to 2.4?
So also the engine response when I tested with the clutch switch connector disconnected and left open and shorted make sense. During normal driving the engine rpms drop and rise slower so as not to shock the transmission.
I think it is worth checking how your clutch switch operates as I do think that it contributes to a big chunk of the Puma drivability. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076805 3rd Oct 2025 3:26pm
2.2 is NO, 2.4 is NC. They are different due to the different ECMs.
Lightning, do you know anyone local with a Puma you could drive and who you could let drive yours? Either your vehicle or technique is causing problems and that would be the easiest way to diagnose which.it is.
Post #1076806 3rd Oct 2025 3:37pm
Dinnu
Thanks BW.
Perhaps your clutch bite point and switch switching point are out of sync. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076808 3rd Oct 2025 3:46pm
lightning
Possibly.
l've noticed that looking at clutch switches, most Ebay sellers are listing them as suitable for "TD5/Puma"
This is almost certainly not the case. The TD5 one operates the opposite way round. l found this out when l had my Defender TD5.
One is normally open and the other is normally closed.
This could cause all kinds of issues. As it did on my TD5 as l was sold a Puma one.
Post #1076809 3rd Oct 2025 3:53pm
90 Dreamer
as mentioned above I had some jerky issues and tried bridging switch, etc (actually made it worse) and in the end simply replaced with a new Genuine LR switch (wasn't any great cost) and its a different drive........
no codes or anything else to suggest it wasn't working
Post #1076811 3rd Oct 2025 4:23pm
Dinnu
If the 2.4 and 2.2 switches operate inverse of each other, then certainly, one of them should be same as a Td5.
Which is the question. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076813 3rd Oct 2025 5:19pm
Martin
Site Admin
Td5 and Puma ones operate in opposite manners. 2.2 Puma and 2.4 Puma are the same.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1076815 3rd Oct 2025 5:56pm
Dinnu
I was curious and checked my 2.2 clutch switch this afternoon. With the multimeter set to continuity, it only started beeping when the clutch pedal was close to half way down. So my clutch switch is wrong? Driving seems fine, but never driven another 2.2 to compare. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076819 3rd Oct 2025 6:07pm
lightning
I have ordered a new OE switch from the registration number so will fit that when it arrives and see if it makes any difference.
Post #1076821 3rd Oct 2025 6:30pm
Page 2 of 3 <123>
