Home > Maintenance & Modifications > Assistance required
big ives
Assistance required
I have an oil leak at the inner rear wheel, yes I have searched and found loads of info but what I really need is the part numbers of the actual seals I need to replace or confirmation that the part numbers I have are correct any help would be great so I can order these and have them at home when I get back in a few weeks.
Landrover 90 V8, 1989 with 10 spline axles and with disc brakes.
I believe I need the following three seals, is my thinking correct? I will change all paper gaskets, washers and locknuts as I have these in stock.
Axle seal (I cannot find any number for this seal) is this the same as stub axle oil seal?
stub axle oil seal FTC3145
Wheel bearing oil seal RTC3511
Many thanks Ivan 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #1076680 2nd Oct 2025 6:23am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
FTC4785 springs to mind for hub seal?
Post #1076689 2nd Oct 2025 8:22am
big ives
just googled
so these go behind the stub axle
Land Rover Stub Axle (inner hub) Seal, Pack of 2 Corteco OEM FTC4785
really my question is on the actual axle housing is there a seal there as well to stop the diff oil running out? or am i getting confused
i have stripped these many time in the past but can not remember......................cheers Ivan 2016 Discovery 4
Post #1076694 2nd Oct 2025 9:18am
jst
there can be a seal there, i tend to leave them out and let axle oil lubricate the bearings.
not all vintages had them there anyway. not all shafts have a flat for them to run on either. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076704 2nd Oct 2025 11:23am
big ives
I have read this somewhere as well
based on your knowledge to stop the oil leak on the rear inner wheel, there is three seals on the rear that can be changed would you have the part numbers at hand?
i have the drawings but not sure of the part numbers...................................cheers Ivan 2016 Discovery 4
Post #1076707 2nd Oct 2025 11:31am
big ives
Based on what I can google and the drawings I can check, these are the seals I require or not?
FTC5268G APPEARS TO BE THE SMALL AXLE SEAL ON THE INNER LIP OF THE AXLE BUT CAN BE LEFT OUT.
FTC4785 GOES ON THE REAR HUB AND SITS ON THE STUB AXLE.
FRC8222 GOES ON THE OUTER HUB
Maybe not the best way to describe where they go but you get the drift Rolling with laughter
cheers Ivan Thumbs Up Thumbs Up 2016 Discovery 4
Post #1076710 2nd Oct 2025 11:48am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Have a look here:
https://parts.jaguarlandroverclassic.com/p...and-rover/
If it's like on later models you will have a paper gasket between the axle casing and the stub axle.
There will be a seal in the stub axle (should be the one jst mentions) that will hold the axle oil in the axle.
There is one seal in the hub which I don't think you need to touch unless you are doing the bearings.
And finally you will need a paper gasket between hub and drive member.
You should be able to find the p/n on the link above.
Post #1076717 2nd Oct 2025 12:37pm
big ives
Johan B
many thanks for the link for sure that is clear what seal i need
as i said the paper gasket etc i have just wanted to be sure i ordered the correct seals
wheel bearings all changed about 18 months back, now changing again but would change the seal when i have everything stripped down
thank you to you and JST Thumbs Up Thumbs Up , parts ordered
cheers ivan 2016 Discovery 4
Post #1076718 2nd Oct 2025 12:50pm
Johan_B
Great! Thumbs Up
Out of curiosity, how does the axle oil come to the bearings? Does it come through the stub axle and then back along the splines into the hub? Only relying on the end cap not to leak externally?
Post #1076722 2nd Oct 2025 1:23pm
big ives
to be honest i am not sure
all i know i have a minor leak on the inside of the rear wheel
so i intend to strip and tey and see where is coming from, the replace all seals, gaskets etc etc
Post #1076766 3rd Oct 2025 2:43am
I Like Old Skool
Johan_B wrote:
Great! Thumbs Up
Relying on memory here....
Original 200 tdi defender rear axle (drum brakes) had a strange seal arrangement that sealed the grease in the hub bearings at the front and the rear. All other Landrover wheel bearings I have encountered used a stub axle seal of some description to keep oil out of the hub bearings, or didn't bother.
In most cases, the oil will migrate along the stub axle and feed into the bearings then be contained by the hub oil seal FTC4785 or equivalent.
Post #1076773 3rd Oct 2025 9:07am
I Like Old Skool
@Big ives
As far as I know, a Landrover 90 of that age would have originally been drum braked rear axle.
This means there has likely been an axle swap at some point to achieve disc brakes all round. Do you know what axle has been fitted? It could be from a Range Rover, or maybe a 200tdi discovery. Is it definitely 10 spline?
Identify the axle and parts spec should be simplified somewhat.
Post #1076774 3rd Oct 2025 9:14am
big ives
@old school
my 90 was originally 3.5v8
100% discs on the back yes the axle was changed a long time ago but not by me and 99% from a RRC
100% 10spline
the oil weeping only just started before the MOT last month, its not bad but annoys the f*** out of me
I do all my own work and all new wheel bearings and seals fitted July 2024
I work aboard and just wanted to have all the parts I need at home when I get back mid October
I just had my wife check the garage (not happy) and send me fotos of what spare seals I had in the box, everything labeled so easy for her (sad I know) and I have the seals in stock, except for the small one that goes into the axle housing, but as JST said u don't need it, and I cant remember checking it July 2024 i .............................cheers ivan 2016 Discovery 4
Post #1076779 3rd Oct 2025 10:11am
