Home > Td5 > Engine Issues
nininu98
Engine Issues
Hi,
I am experiencing an intermittent starting issue with my 2006 Defender 90 TD5.
When I turn the key to the ON position, I wait for the glow plugs to switch off, hear the fuel pump prime, and then turn the key to the START position. The vehicle cranks, starts immediately, runs for 3–5 seconds, and then switches off.
During this, there is no check engine light on the dashboard, only the oil and battery lights. If I then turn the key back to the OFF position, repeat the process (wait for glow plugs, fuel pump priming, then crank), the vehicle starts and runs normally.
Once running, it drives without any issues. If I drive for a few miles, switch it off, and restart, it usually starts immediately with no problems. However, the issue occurs randomly.
Work already carried out:
Full oil and filters service (including a new, good-quality fuel filter)
New genuine injector seals and washers replaced this week
Genuine fuel pump replaced 3 years ago (approx. 14,409 miles since)
Full diesel tank
Battery tested under cranking load – all good
Starter motor contact points replaced 4 years ago
Checked the injectors harness plug and no traces of oil. This was changed 6,700 miles ago
Checked red ecu plug and had very little (2 drops) traces of oil, which is now cleaned
No error codes showing. The check engine light does not show on the dashboard lights as can be seen in the video.
Issue video:
https://drive.google.com/file/d/1A2mf7hsFc...drive_link
Despite the above, the issue persists.
Could you please suggest what to check next, or what may be the likely cause of this problem?
Thank you.
Post #1075978 23rd Sep 2025 12:20pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
Check your inertia switch is operating correctly,
The coolant gauge moving to overheat would leave me to believe this is faulty. Could be faulty and misreading a signals and cutting fuel off.
Post #1076022 23rd Sep 2025 10:47pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Try the fuel purge cycle before the firt problematic start. It should be related with not enough fuel in engine/bubles of air in fuel.
If this help, look for any fuel leaks - mainly fuel pressure regulator and fuel filter head.
Simple to change is fuel filter. A bit harder fuel filter head, fuel pressure regulator, in tank fuel pump or injector seals. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1076034 24th Sep 2025 6:37am
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
I agree - look for fuel pressure issues/signs - I had a similar (but not running as long as 3-5 seconds, more like 1) when my FPR was leaking on the back of the cylinder head. Tell tale diesel leaking down the back of the engine.
New FPR and gaskets etc in the existing housing made it start a lot more reliably and stopped the leak.
Post #1076066 24th Sep 2025 1:26pm
Roukmuth
France 2002 Defender 110 Td5 SW Epsom Green
Indeed, your problem could be related to the FPR (fuel pressure regulator). Check if there is a leak around that area.
It's a relatively easy component to replace. Here's a tutorial on how to do it.
https://meca1.co.uk/dm1-ab-regulpresgotd5/
Post #1076134 25th Sep 2025 8:16am
nininu98
Thank you all for your help. I’m posting how I managed to solve it. I did two specific things on the same day, and I’m not sure which one actually fixed it, so I’m sharing both.
1.
As DefenderCan had suggested, I checked the inertia switch and reset it. The first click felt a bit stuck, but after resetting it three or four times, the click felt smoother.
2.
I had also read on another topic(https://www.defender2.net/forum/topic44329.html?view=next) to check the two yellow relays next to the ECU. I removed them, lightly sanded all the relay contacts with fine sandpaper, adjusted the contacts slightly, and added a cable tie to ensure a secure connection.
Since doing these two things on the same day, I haven’t experienced the engine switching off again. It’s been running normally for four days now, so one of the above must have solved the issue. Smile
Thanks again for all your help!
Post #1076458 29th Sep 2025 10:25am
DefenderCan
Glad you resolved the issue, Ill elaborate for any future people seeing this thread, the inertia switch is essentially a fuel cut off switch in the case of an accident. There is a gyroscope that controls the switch and in the case of a crash with trigger the fuel cut off. For example, a roll over..... however, in some cases it will trigger just because many factors.... hence why there is a reset button for in cases it accidental triggers
They actually sell fuel cutoff switches for theft prevention that is connected to the inertia
As mentioned, when your coolant gauge goes to the red instantly, telltale sign.
Perhaps designed that way so people know to when to click the reset button however can be very misleading.
Post #1076606 1st Oct 2025 7:15am
MadTom
Just to make it clear, there is no gyroscope in the switch, just a heavy piece of metal. It is just a turn iver switch, that opens circuits when rhe car turned over, or during bit hit. And sometimes even during harder offroad ride. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1076636 1st Oct 2025 3:22pm
DefenderCan
Correct , a ball on a magnet.
Post #1076645 1st Oct 2025 4:44pm
