![]() | Home > Puma (Tdci) > extra fuel filter for overlanding |
You can just put a small transparent inline one on the fuel line if you feel like it.
Speak to Leeds / Brendan, he's fitted safari equip 120ltr main and 48ltr aux tank to his 110 puma USW
![]() 2011MY 110 XS USW Black |
I think he said filter, not tank
Errr yes we have fitted larger tanks to our vehicles.
As for additional fuel filters if I remember correctly Land Rover supplied 110's for abroad with an extra fuel filter in the (UK) offside rear wheel arch. Glass bodied and referred to as a sedimentor?? Question would be why do you wish to install a second fuel filter? Brendan |
One of the issues with a puma is that there is no tank bung so you can't drain it if you have a problem. For certain places I guess an in line filter might be useful, but to be honest I can't really think of any unless you plan to go somewhere where they might fill your vehicle from drums.
HotelCharlie Member Since: 20 Oct 2011 Location: Kavala, Greece Posts: 25 ![]() ![]() ![]() |
Just moved to Morocco for work, brought my 2007 110CSW with me and plan to push south as often as possible with local 4x4 enthusiasts.
Puma engines (injectors) are not happy with water, less than previous Land diesel engines. Diesel quality has surprised locals on occasions, in remote areas, most use fuel separators (helps with solids as much as water). And large or numerous tanks, increase the surface left for condensation to form, problem helped by large temperature range between day and night (the solution is to be fueled up for the night: no space for condensation to form! but not always practical). Seen and heard about the Racor from locals, so wondered about their use on Pumas. Thanks for the inputs |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello dear neighbor,
Take a look at this: http://www.laboutiqueduland.com/329-decanteur-de-gasoil-td4.html I have it on mine. It seems to be good. A+ |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
I found this Racor fuel filter. I suppose It directly replace the standard fuel filter assembly:
http://www.euro4x4parts.com/parts/frp1005-...ra230.html Anyone is using it ? @Apynala: The filter suggested in your link look like the standard filter, could you better describe it ? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Try the AULRO.COM,the Australian Land Rover site.They do a lot of overland preparation stuff there. If there's a way to do it,someone there will know. 1982 88" 2.25 diesel
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
OE filter is designed to filter down to 5um particle size (not 20um like the racor). And since the main injection pump does all the work, I doubt an extra filter would work.
By accident I broke my fuel filter holder and I had to put 2 std filters (one on each line) to get away. I can tell the engine did not like it. At least this setup. I would take enough OE filters (mahle, mann, fuelmanager, etc. They are all good) and drain them more often. I also recommend to take the tank-filter tube spare. Puma 110" SW ............................................................. Earth first. Other planets later |
Thanks for pointing me to AULRO.COM, I found many interesting discussion Puma related.
This is fuel filter related: http://www.aulro.com/afvb/90-110-130-defen...-fuel.html There are some reference about the RACOR 445R-2 filter http://www.allpointsmarineco.com/images/up...83c846.jpg It's an interesting product that can probably replace the stock fuel filter and feature an integrated manual priming pump, clear bowl, filtering up to 2 micron and optional heating and water detection sensor. |
