|  | Home > Puma (Tdci) > extra fuel filter for overlanding |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | You can just put a small transparent inline one on the fuel line if you feel like it. | ||
|  15th Dec 2011 6:10pm |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785      | Speak to Leeds / Brendan, he's fitted safari equip 120ltr main and 48ltr aux tank to his 110 puma USW   Russell 2011MY 110 XS USW Black | ||
|  15th Dec 2011 6:17pm |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | I think he said filter, not tank    | ||
|  15th Dec 2011 6:34pm |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584    | Errr yes we have fitted larger tanks to our vehicles.
 As for additional fuel filters if I remember correctly Land Rover supplied 110's for abroad with an extra fuel filter in the (UK) offside rear wheel arch. Glass bodied and referred to as a sedimentor?? Question would be why do you wish to install a second fuel filter? Brendan | ||
|  15th Dec 2011 6:43pm |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | One of the issues with a puma is that there is no tank bung so you can't drain it if you have a problem. For certain places I guess an in line filter might be useful, but to be honest I can't really think of any unless you plan to go somewhere where they might fill your vehicle from drums. | ||
|  15th Dec 2011 6:47pm |
| HotelCharlie Member Since: 20 Oct 2011 Location: Kavala, Greece Posts: 25      | Just moved to Morocco for work, brought my 2007 110CSW with me and plan to push south as often as possible with local 4x4 enthusiasts.
 Puma engines (injectors) are not happy with water, less than previous Land diesel engines. Diesel quality has surprised locals on occasions, in remote areas, most use fuel separators (helps with solids as much as water). And large or numerous tanks, increase the surface left for condensation to form, problem helped by large temperature range between day and night (the solution is to be fueled up for the night: no space for condensation to form! but not always practical). Seen and heard about the Racor from locals, so wondered about their use on Pumas. Thanks for the inputs | ||
|  15th Dec 2011 7:47pm |
| Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88      | Hello dear neighbor,
 Take a look at this: http://www.laboutiqueduland.com/329-decanteur-de-gasoil-td4.html I have it on mine. It seems to be good. A+ | ||
|  15th Dec 2011 8:14pm |
| MD5 Member Since: 02 May 2011 Location: Italy Posts: 143    | I found this Racor fuel filter. I suppose It directly replace the standard fuel filter assembly:
 http://www.euro4x4parts.com/parts/frp1005-...ra230.html Anyone is using it ? @Apynala: The filter suggested in your link look like the standard filter, could you better describe it ? | ||
|  16th Dec 2011 7:51pm |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813    | Try the AULRO.COM,the Australian Land Rover site.They do a lot of overland preparation stuff there. If there's a way to do it,someone there will know. 1982 88" 2.25 diesel
 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai | ||
|  16th Dec 2011 8:47pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | OE filter is designed to filter down to 5um particle size (not 20um like the racor). And since the main injection pump does all the work, I doubt an extra filter would work.
 By accident I broke my fuel filter holder and I had to put 2 std filters (one on each line) to get away. I can tell the engine did not like it. At least this setup. I would take enough OE filters (mahle, mann, fuelmanager, etc. They are all good) and drain them more often. I also recommend to take the tank-filter tube spare. Puma 110" SW ............................................................. Earth first. Other planets later | ||
|  17th Dec 2011 10:05am |
| MD5 Member Since: 02 May 2011 Location: Italy Posts: 143    | Thanks for pointing me to AULRO.COM, I found many interesting discussion Puma related.
 This is fuel filter related: http://www.aulro.com/afvb/90-110-130-defen...-fuel.html There are some reference about the RACOR 445R-2 filter http://www.allpointsmarineco.com/images/up...83c846.jpg It's an interesting product that can probably replace the stock fuel filter and feature an integrated manual priming pump, clear bowl, filtering up to 2 micron and optional heating and water detection sensor. | ||
|  18th Dec 2011 7:39pm |
| Posting Rules
