Home > Maintenance & Modifications > Got a cheap NAS rear bumper: crossmember holes to large?
Clustered
Netherlands
Picked up a cheap NAS rear step bumper for my 110. When I slide the bumper’s arms into the rear crossmember jacking points, there’s a lot of play.
Is the issue that the jacking point holes on the crossmember are oversized on older Defenders? Or could it be that the bumpers arms have rusted away? Strange thing is, if they did rust out, both sides would have gone in almost exactly the same way. There is some rust on them, but don't really expect it to have rusted out over 1cm, and so round as well.
Or is this just how these bumpers fit from the factory?
Post #1076426 28th Sep 2025 5:42pm
Screbble
I’m intrigued and hope someone will enlighten both of us 👍
Post #1076427 28th Sep 2025 6:03pm
BrickBox
To me - it’s looks like the bumper arms that slide into the crossmember are heavily corroded and have lost a couple of layers of metal…. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1076431 28th Sep 2025 6:45pm
Clustered
Netherlands
Hmm, but both arms seem of equal thickness. That would mean some very equal rust decay.
Post #1076432 28th Sep 2025 7:14pm
Mdm
assume your crossmember is original as some aftermarket ones are very poorly buit,l i suspect like others its heavily corroded and lost a fair bit of metal.
the nas step design is a very poor one and helps the rear end of defender rot faster, the bars themself are poorly made and rust quickly.
you could replace the tubes with correct size if there is any good metal to weld to.
or buy a galvanized new nas step
Post #1076435 28th Sep 2025 8:29pm
90 Dreamer
have measured a little used stored one in good condition and the pins are slightly over 26mm........
Post #1076450 29th Sep 2025 8:53am
Clustered
Netherlands
That is still significantly less than the holes in the rear crossmember?
Post #1076457 29th Sep 2025 9:56am
I suspect that the pins are designed to be a very loose fit in the holes due to LR's legendary manufacturing tolerances. The pins serve little purpose and are hardly critical.
I though, but could be wrong, that the front end of the pins (i.e., the end that goes into the hole) was drilled and tapped for a setscrew and washer, further rendering the fit in the hole irrelevant. However I freely confess to knowing relatively little about the NAS step since I have always regarded it as a unattractive and pointless rust trap.
Post #1076459 29th Sep 2025 10:34am
jst
chassis may have lost a bit, pins look to have lost alot. just fit with bolt on other side which genuine ones have that Blackwolf eludes to. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076462 29th Sep 2025 11:27am
Martin
Site Admin
Fitting instructions:
https://www.defender2.net/gallery/albums/u...Bumper.pdf
Step 13 is the large washer and bolt into the end of that tube.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1076463 29th Sep 2025 11:34am
Mo Murphy
It was cheap, it doesn't fit well, it's well used and quite rusty. I think perhaps your expectations are a little too high.
50 Shades of Pennine Grey
Post #1076477 29th Sep 2025 4:28pm
Linds Hanson
They are like that from new they come with a large stepped washer that sits in the chassis tube and overhangs the chassis tube to clamp the step spigots to the chassis l
Post #1076498 29th Sep 2025 8:14pm
TexasRover
Lol interesting how the NAS rear bumper bracket has no USA type certification. Also as per the drawings it does not have the square receiver, which I would consider the main benefit of an NAS rear bumper.
Why exactly is it named NAS exactly?
Post #1076502 29th Sep 2025 9:17pm
jst
NAS - needs another solution Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076504 29th Sep 2025 10:01pm
Mo Murphy
🤣 The Land Rover 90 - Many are called, few are chosen.
Post #1076560 30th Sep 2025 1:56pm
