Home > Td5 > TD5 - Oil Leak from Inlet side
jonny
Hi
My TD5 has started marking it's territory - oil is dripping from the bottom of the gearbox bell housing / block join if it's left for a while...
Looking underneath, I can't see anywhere obvious it's coming from - it looks like there's oil residue underneath the engine mount, and high up on the block, above the base of the dipstick tube, but it's hard to see clearly with the inlet and all of the gubbins in the way. It's definitely oil as it's dirty black, not diesel.
Is there a 'usual suspect' round there that can leak?
Thanks!
Post #1076388 28th Sep 2025 12:21pm
landy andy
Check your fuel pressure regulator. They often leak and then run around the back of the engine washing oil off and becoming black with clutch dust.
Post #1076390 28th Sep 2025 12:40pm
jonny
Thanks - had a feel round there, and the FPR itself is dry - no leaks from the unions etc and no diesel-smelling fluids.
However, on the underside of it, where it's bolted to the block, and under the inlet runners of 4 / 5 there's oil - not a massive amount, but enough to make your fingers dirty...
Post #1076396 28th Sep 2025 1:17pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Mine used to leak on the inlet side - check that it isn't the alternator/vacuum pump join. There's a seal between the two which can fail, especially (as in my case) if the bearing on the back of the alternator has failed and the vacuum pump is doing the heavy lifting as a result. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1076398 28th Sep 2025 1:45pm
jonny
Thanks - I had a feel round there and it all seems to be dry...
Post #1076421 28th Sep 2025 4:08pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Rocker cover gasket or dreaded rear main seal? 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone)
1994 Defender 90 300Tdi CSW (gone)
Post #1076424 28th Sep 2025 4:26pm
jonny
The rocker cover gasket doesn't appear to be leaking much at all - however I need to do the injector loom at some point, so I've got a new gasket, cam plug thing and O ring on the way anyway..
Hopefully it's not the rear main seal!!
Post #1076425 28th Sep 2025 4:41pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
Rear main seal
Post #1076441 29th Sep 2025 2:16am
