Home > General & Technical (L663) > Linking Keys to Profiles and or seat positions
testpilottimmy
I have searched and seen some very old threads on this topic. From what I have been able to find, there is no way to link a key to either a profile or seat position, can anyone confirm if this is still true, or am I missing something?
Seat position is my main issue, as my wife, despite being slightly shorter than me, has legs that are significantly longer than mine. To the point where it is awkward for her to get into a car after I have been driving it! I only got the car (MY26) on Friday, so it’s all new to me.
Post #1076362 28th Sep 2025 8:05am
markb110
Why not just set the seat memory position including reverse mirror setting using the number keys on the door?
I press that on wifeys DS before I get in the car…….
Post #1076363 28th Sep 2025 8:13am
Gareth
Profiles used to be a thing on mine (2021). However I seem to recall it never worked properly and was disabled during an update?
I just keep the steering adjust set to Auto, and use the memory buttons on the door.
Steering adjust set to auto means that the seat and wheel move away from each other when the car is shut down to ease entry/exit. Search Entry & Exit mode on IGuide.
I do find that the seat memory sometimes needs a second press to fully position everything. Not sure why. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1076368 28th Sep 2025 8:51am
testpilottimmy
Thanks - there are profiles in Pivi Pro, but it seems no link to the key or seats. We can manually select on the door, I’m just used to other cars where the seat is moved to your position when you unlock the car with your key.
Post #1076373 28th Sep 2025 8:59am
