![]() | Home > General & Technical (L663) > Linking Keys to Profiles and or seat positions |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Why not just set the seat memory position including reverse mirror setting using the number keys on the door?
I press that on wifeys DS before I get in the car……. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1141 ![]() ![]() |
Profiles used to be a thing on mine (2021). However I seem to recall it never worked properly and was disabled during an update?
I just keep the steering adjust set to Auto, and use the memory buttons on the door. Steering adjust set to auto means that the seat and wheel move away from each other when the car is shut down to ease entry/exit. Search Entry & Exit mode on IGuide. I do find that the seat memory sometimes needs a second press to fully position everything. Not sure why. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
testpilottimmy Member Since: 20 Jul 2025 Location: Guildford Posts: 14 ![]() ![]() |
Thanks - there are profiles in Pivi Pro, but it seems no link to the key or seats. We can manually select on the door, I’m just used to other cars where the seat is moved to your position when you unlock the car with your key.
