![]() | Home > Td5 > Lost interior light |
| PauloA Member Since: 29 Apr 2024 Location: Bristol Posts: 48
Door switches would be the next thing I'd check. They're notoriously susceptible to corrosion on the contact surfaces but it's a fairly easy fix (one screw to remove each one).
Good luck! Cheers, Paul |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
That was my first go to. But they look ok. When I’ve had failed ones before, it has just been that the one individual door doesn’t work.
This time I’ve no lights. |
Do the interior lights and switches go through the alarm controller? Mine's a 300tdi so it's pretty simple but the TD5 electronics might have an influence here? Sorry, I'm not going to be much more help here! Cheers,
Paul |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
Might help
I don’t think it is the door switches because if I set the alarm/use CL with a door open the horn gives two honks, as it acknowledges the door is open.
I’m thinking it may be a 10AS thing. |
Just had a play. Still struggling with it
But. Fiddling triggered the alarm to sound. It’s now changed to a long HHHHHHHHHOOOOOOOOOOONNNNNNNNNNKKKKK Not the normal HONK. HONK. HONK. Does this information mean anything??? |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736
LEDs in the interior light(s) or filament bulbs?
10AS has a 20A fuse (fuse 7) and 15A fuse (fuse 6) under the seat that are worth a look. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
The lights are LED. NAK ones and fitted for 5-6 years.
All fuses in under dash and under seat have been checked. Will double check them though What fuses on under dash are relevant? Don’t want to pull stereo one again. What a PITA. |
| All times are GMT |
