Home > Td5 > Lost interior light
landy andy
Lost interior light
My interior light has stopped working.
I can physically turn it on and all is ok
BUT
When I unlock the doors I get a quick flash from the light and that is it. No like it was when it remained on for a period of time. I also get no light when opening a door.
I have checked the fuses under the dash, but not the unseat fuses yet.
Any thoughts??
Post #1076251 26th Sep 2025 6:28pm
PauloA
United Kingdom 1997 Defender 90 300 Tdi HT Oslo Blue
Door switches would be the next thing I'd check. They're notoriously susceptible to corrosion on the contact surfaces but it's a fairly easy fix (one screw to remove each one).
Good luck! Cheers,
Paul
Post #1076252 26th Sep 2025 6:34pm
landy andy
That was my first go to. But they look ok. When I’ve had failed ones before, it has just been that the one individual door doesn’t work.
This time I’ve no lights.
Post #1076261 26th Sep 2025 7:59pm
PauloA
Do the interior lights and switches go through the alarm controller? Mine's a 300tdi so it's pretty simple but the TD5 electronics might have an influence here? Sorry, I'm not going to be much more help here! Cheers,
Paul
Post #1076266 26th Sep 2025 8:51pm
Screbble
Might help Thumbs Up
Post #1076267 26th Sep 2025 9:15pm
landy andy
I don’t think it is the door switches because if I set the alarm/use CL with a door open the horn gives two honks, as it acknowledges the door is open.
I’m thinking it may be a 10AS thing.
Post #1076291 27th Sep 2025 9:27am
landy andy
Just had a play. Still struggling with it
But.
Fiddling triggered the alarm to sound.
It’s now changed to a long HHHHHHHHHOOOOOOOOOOONNNNNNNNNNKKKKK
Not the normal HONK. HONK. HONK.
Does this information mean anything???
Post #1076301 27th Sep 2025 10:59am
Martin
Site Admin
LEDs in the interior light(s) or filament bulbs?
10AS has a 20A fuse (fuse 7) and 15A fuse (fuse 6) under the seat that are worth a look.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1076303 27th Sep 2025 11:36am
landy andy
The lights are LED. NAK ones and fitted for 5-6 years.
All fuses in under dash and under seat have been checked.
Will double check them though
What fuses on under dash are relevant?
Don’t want to pull stereo one again. What a PITA.
Post #1076311 27th Sep 2025 1:56pm
