![]() | Home > Puma (Tdci) > OIL LIGHT |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3877 ![]() ![]() |
Has she far to drive home?
I would suggest to top up some oil as soon as possible and then when home check when cold. If she hasn't far (non motorways etc) I would suggest it should hopefully be ok? Oil however is much cheaper than if it runs out. Keep an eye on the temp driving home, I have a ultra guage plugged in which does give a lot better (accurate readings) THe dashboard temp hardly moves according to the dial. Hopefully all ok ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8448 ![]() ![]() ![]() |
Check the level before it's driven anywhere. Cheers
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3439 ![]() ![]() |
Any news on this, was the engine okay
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 41 ![]() ![]() ![]() |
possible a dodgy switch, just have her send you a photo of the oil level on the dipstick before topping up. If she is not knowledgeable, she may overfill the sump and start blowing seals.
