Home > Td5 > Removing the Cat conv?
Terre Rouge
France
One of my Defs is a 2005 110 with 250k kms. My nearest remap specialist in Albi refuses to remap it due to the high kms. I’ve already removed the ERG, my question is…will removing the Cat Conv make it a little less of a tank to drive?
Merci
Post #1060398 12th Feb 2025 5:50pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Anything allowing more free flowing exhaust will help. Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1060400 12th Feb 2025 6:08pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
it makes the turbo spool up slightly faster.
it also gets rid of the issue of the passenger's feet feeling hot (assuming the steering wheel is on the right) on a long drive.
it also changes the smell of the exhaust.
you can also consider removing the mid box, but keep the smaller one at the end. it sounds nice. The defender has migrated, leaving the owner behind.
Post #1060838 18th Feb 2025 11:16am
TexasRover
I doubt CAT is much of an obstruction assuming not blocked, same with muffler etc. This would only create a small amount of HP gain at higher RPM when the engine is probably screaming already and will make no difference to normal driving and acceleration. My current Td5 has the cat and I recently drove the same year 110 with the CAT removed and there was no noticeable difference other than some turbo whistle.
The CT (MOT) in France is not too intelligent, compared to say the German TuV, but there is still the risk that emissions equipment is noticed as being absents.
Unless the cat is blocked I would keep it just fine.
Post #1060849 18th Feb 2025 12:45pm
Jabberwocky
Luxembourg
If there are concerns about failing an MOT, some companies do Cat shells, they look like a CAT but are empty inside. Or buy an early TD5 that don’t have CATs🤷‍♂️😁😁
Post #1061066 21st Feb 2025 8:59pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
10p have plastic dowels guiding the block to the head.....
just a heads up
Post #1075844 21st Sep 2025 9:42am
lightning
l removed the CAT and EGR from my 2005 Defender TD5 and noticed no difference at all.
Post #1076436 28th Sep 2025 8:14pm
DefenderCan
Removing the cat is beneficial for any vehicle. It is a restriction. Here is a more technical break down…
The goal for any vehicle looking to get better performance is to try and max out the coldest and highest air density in the combustion chamber. A cat will reduce the emissions being exhausted in the exhaust stroke, in turn reducing how much air is being sucked into the combustion chamber giving
rough running or in other words can give reducing the amount of air density in the chamber. Removing a cat and egr maxes your air density leading to a clean burn. A TD5 runs very clean hence even on over fuelling you won’t see a lot of smoke for a standard remap. A cat is only for smoke something I believe hence why when it first came out it wasn’t needed.
Another example is simply driving up hill and not having to drop a gear, I can pull a steep incline on pavement in 5th gear, before had to drop from either 4th or 3rd.
Now it’s not a supra so don’t expect crazy results but you will have a smoother and healthier running truck in turn which will give you longevity. Hope this helps.
Post #1076442 29th Sep 2025 1:25am
