Home > Puma (Tdci) > Centre Console Lighting Loom
Page 2 of 2 <12
PaulMc
The bulb holders aren't moulded to the cables, they have terminals crimped to the cables, which are inserted into the bulb holders -
I've looked high and low for a matching or similar terminal, without success Sad
I've also looked for a similar bulb holder that could be modified - but, the majority of the readily available ones are the PCB contact bayonet fixing type, which aren't really suitable.
. Paul.
Post #953903 28th May 2022 5:58pm
Dibble04
United Kingdom 2011 Defender 110 Puma 2.4 PU Java Black
I was'nt aware the terminals could be removed from the moulding. I wonder whether 3d printing could help with new mouldings...shall have a word with a friend in that industry.
Meanwhile, I guess all we can do is keep looking.
Thanks again
Post #953908 28th May 2022 6:22pm
I agree with Blackwolf regards to LED for those.
I tried that and found also that they weren’t any good, a real pain seeing as it’s so involved to get at them.
I hoped they’d perform better, they didn’t and last longer, they didn’t.
In fact the ones I had failed faster that incandescent standard capless 1.2w ones.
One or two LED’s went completely another kept randomly flashing was was extremely annoying!
In the end I replaced them with Lucas 1.2w and they’ve been fine so the supposed upgrade I hoped was no such thing and a waste of time.
Regarding the loom, I’d check out somewhere like Thornton breakers.
They perhaps may want to sell you the whole part but maybe that’s cheaper than alternatives and if used then maybe worth it.
If you don’t ask you don’t get, presumably they might have one in they might not but just an idea.
Maybe failing that get the ones like Paul suggested from one of those manufacturers from a breaker and cut and splice your own loom using wire tails.
Though some soldering and heat shrinking would be needed.
Hope there is some ideas there, some of these things can be a pain to source and some not possible to source at all. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #953935 28th May 2022 8:47pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
2.2 puma heater control panel bulb holders loom
Has anybody had any joy finding replacement bulb holders as mine have fallen to bits Sad
Post #1075311 13th Sep 2025 10:51am
HardCharger
A related question, do you use the bulbs for these as is or do they need the green sleeve / condom thing to tint them green? Question No Better Friend, No Worse Enemy
Post #1075494 16th Sep 2025 4:48am
Iktank
found a loom and plugs that does fit, all be a bit more cable than the Defender item.
All that needs to be done is change the primary cable connection plug
- Fiat Punto heater illumination wiring loom with bulbs
Post #1075794 20th Sep 2025 1:59pm
PaulMc
Good find Thumbs Up Paul.
Post #1075812 20th Sep 2025 7:31pm
BrickBox
That’s an unbelievable among digging! But it’s paid off - well done 👏 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1075813 20th Sep 2025 8:49pm
Page 2 of 2 <12
