![]() | Home > Puma (Tdci) > Centre Console Lighting Loom |
Dibble04 Member Since: 13 Feb 2022 Location: Devon Posts: 34 ![]() ![]() ![]() |
I was'nt aware the terminals could be removed from the moulding. I wonder whether 3d printing could help with new mouldings...shall have a word with a friend in that industry.
Meanwhile, I guess all we can do is keep looking. Thanks again |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
I agree with Blackwolf regards to LED for those.
I tried that and found also that they weren’t any good, a real pain seeing as it’s so involved to get at them. I hoped they’d perform better, they didn’t and last longer, they didn’t. In fact the ones I had failed faster that incandescent standard capless 1.2w ones. One or two LED’s went completely another kept randomly flashing was was extremely annoying! In the end I replaced them with Lucas 1.2w and they’ve been fine so the supposed upgrade I hoped was no such thing and a waste of time. Regarding the loom, I’d check out somewhere like Thornton breakers. They perhaps may want to sell you the whole part but maybe that’s cheaper than alternatives and if used then maybe worth it. If you don’t ask you don’t get, presumably they might have one in they might not but just an idea. Maybe failing that get the ones like Paul suggested from one of those manufacturers from a breaker and cut and splice your own loom using wire tails. Though some soldering and heat shrinking would be needed. Hope there is some ideas there, some of these things can be a pain to source and some not possible to source at all. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 245 ![]() ![]() ![]() |
2.2 puma heater control panel bulb holders loom
Has anybody had any joy finding replacement bulb holders as mine have fallen to bits ![]() |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 792 ![]() ![]() ![]() |
A related question, do you use the bulbs for these as is or do they need the green sleeve / condom thing to tint them green?
