Home > Puma (Tdci) > Engine (Turbo?) hesitation at specific RPM
Kez
Isle Of Man
Defender has developed a new problem, while gently accelerating it sort of loses power at exactly 1,800rpm and will continue to 'flutter' or kangaroo until it hits 2,200 rpm or I press the loud peddle harder and accelerate though it. Mostly noticeable when pulling out into traffic or about town etc, once your in anything above 2nd gear its less noticeable. Feel like turbo is cutting in and out, but its fine at all other speeds / RPM
Shocked
Post #107553 15th Dec 2011 10:40am
dgardel
Italy
Re: Engine (Turbo?) hesitation at specific RPM
Shocked
99% EGR
try to disconnect it (the electrical connector) and try again.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #107577 15th Dec 2011 12:23pm
Kez
Isle Of Man
Thank for the advice, do you mean disconnect it and drive with ot disconnected OR disconnect, reconnect and drive again?
Post #107579 15th Dec 2011 12:32pm
Kez
Isle Of Man
dgardel, it worked, did as you suggested, disconnected it and it runs fine SO - what do I do now, is it OK to run it like it is, if not I guess I just have to get a new valved fitted or did the blanking plate concept ever get finalised, and if so whats the advantage of that? Any advice most welcome
Post #107590 15th Dec 2011 1:22pm
Just another thought do you have a re-map & decat pipe ?
Post #107591 15th Dec 2011 1:29pm
Kez
Isle Of Man
yes has no cat or centre silencer, but its worked find for 4 years - and as I say above, disconnecting the EGR has stopped the problem if not fixed it Shocked
Post #107594 15th Dec 2011 1:47pm
