Home > In Car Electronics (L663) > Meridian to retrofit Meridian Surround Amplifier
awktm
Australia
Wanting to upgrade the Meridian amplifier to the more powerful Meridian Surround amp. Does anyone with TOPIX have the pin layouts for the two amps to share?
Assuming it is the same connectors plus the two rear and two centre speaker connections. I don’t really care for the surround function, anyone know if you can just add the more powerful amp and still run just the 11 speakers instead of the surround 15 speakers?
Post #1038522 27th Jun 2024 3:24am
awktm
Australia
This might help someone, I have worked out these are the pinouts:
I have now wired in the amp to all existing 11 speakers and working. I now need to add the rears in the headlining (or similar location) as the backup sensors beep on those speakers.
I would also like to add the front mid and tweeter to get a better soundstage. Next project is working out how I wire up through the telematics module so I don't lose the telematics function.
Post #1042113 7th Aug 2024 11:12am
elvin
Australia
Impressive! Thank you for posting this and keen to see any more follow ups!
Post #1042177 8th Aug 2024 3:16am
haymeister
Japan
Indirectly related:
Can you confirm that the front centre speaker above the front air vents is present (it is there for me) but it is not active and there is no sound? And if I were to retrofit the Meridian Surround Amp then this would 'activate' the front centre speaker? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1042185 8th Aug 2024 6:45am
awktm
Australia
It is a different speaker, you would need to upgrade that speaker and also add the tweeter. You would then need to activate the speaker and run wires for the tweeter.
I am happy with the sound without the front centre channel
Post #1045795 14th Sep 2024 1:23pm
isugoo
United States
I just want to thank you for sharing this. Very helpful for my upcoming audio upgrade planning.
Post #1067853 15th May 2025 9:39pm
Just out of curiosity, where did LR fit the factory Amp? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067857 15th May 2025 10:19pm
isugoo
United States
Amp is in the left side trunk side wall (at least for the US cars).
Post #1067937 17th May 2025 5:43am
Thank you - interesting to know. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067971 17th May 2025 5:32pm
SynergyAero
United States
Great info, thank you! Does anyone know if there is a MOST connector in the system anywhere? Does not appear to be one at this amp (same one as pictured above). I am integrating with my Meridian 16-ch surround system, and trying to avoid the complication of de-equalizing and summing the channels.
Post #1068911 1st Jun 2025 8:53pm
Fifth Horseman
None of the current Landrover audio systems use MOST. IIRC the last ones that did were the L319, L320 & L322 (D4, RRS & FFRR) and L405 up to about 2016 Defender 110 D300 X-Dynamic HSE MY22
Defender 110 Station Wagon 2011 (gone)
Defender 110 DCPU 2007 (gone)
Post #1068919 1st Jun 2025 10:35pm
SynergyAero
United States
Thank you Fifth! I'm planning to just use a Helix Ultra S DSP to handle the pre-amp signals.
On a side note, has anyone been able to source the connectors that would mate to the factory plugs going into the amp? I would love to make my own harness for the pre-amp signals and for the speaker outputs, so that I do not have to cut the factory harness.
Post #1071924 21st Jul 2025 5:42pm
isugoo
United States
I recently upgraded front 3-way speakers. And in process of upgrading rear speakers, subwoofer (under rearseat on D90) and Helix V12 amp.
My shop I used for a few cars were really good at finding OEM harnesses so far. But they had difficult time for LR but found 3 out of 4 (needing one female I believe - its on backorder and ETA to ship from EU end of the month). Once they get it and I'll install and let you know if it's all correct ones then you can order it from my shop in SoCal.
Post #1071929 21st Jul 2025 6:27pm
robcollie
United States
Did you make a harness adapter to fix the mismatch on the speakers between the two amps or did you just move the wires to the correct positions?
Also, this is old but there should be a center speaker preset. It’s used for the SOS feature just turned off via the ccf. It worth turning on if you swap the speaker, otherwise the low quality speaker muddys things a bit.
Post #1074068 26th Aug 2025 4:33am
isugoo
United States
My shop just finished installing complete 10 aftermarket speakers and Helix V12 amp on my base Meridian system. They finally received the harnesses both male and female so they made their own harness set. Thank you sharing wiring diagrams. Everything was spot on and saved a lot of time figuring out wire by wire.
Post #1075720 19th Sep 2025 4:25am
