Home > In Car Electronics (L663) > Meridian to retrofit Meridian Surround Amplifier
awktm
Australia
Wanting to upgrade the Meridian amplifier to the more powerful Meridian Surround amp. Does anyone with TOPIX have the pin layouts for the two amps to share?
Assuming it is the same connectors plus the two rear and two centre speaker connections. I don’t really care for the surround function, anyone know if you can just add the more powerful amp and still run just the 11 speakers instead of the surround 15 speakers?
Post #1038522 27th Jun 2024 3:24am
awktm
Australia
This might help someone, I have worked out these are the pinouts:
I have now wired in the amp to all existing 11 speakers and working. I now need to add the rears in the headlining (or similar location) as the backup sensors beep on those speakers.
I would also like to add the front mid and tweeter to get a better soundstage. Next project is working out how I wire up through the telematics module so I don't lose the telematics function.
Post #1042113 7th Aug 2024 11:12am
elvin
Australia
Impressive! Thank you for posting this and keen to see any more follow ups!
Post #1042177 8th Aug 2024 3:16am
haymeister
Japan
Indirectly related:
Can you confirm that the front centre speaker above the front air vents is present (it is there for me) but it is not active and there is no sound? And if I were to retrofit the Meridian Surround Amp then this would 'activate' the front centre speaker? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1042185 8th Aug 2024 6:45am
awktm
Australia
It is a different speaker, you would need to upgrade that speaker and also add the tweeter. You would then need to activate the speaker and run wires for the tweeter.
I am happy with the sound without the front centre channel
Post #1045795 14th Sep 2024 1:23pm
isugoo
United States
I just want to thank you for sharing this. Very helpful for my upcoming audio upgrade planning.
Post #1067853 15th May 2025 9:39pm
Just out of curiosity, where did LR fit the factory Amp? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067857 15th May 2025 10:19pm
isugoo
United States
Amp is in the left side trunk side wall (at least for the US cars).
Post #1067937 17th May 2025 5:43am
Thank you - interesting to know. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067971 17th May 2025 5:32pm
SynergyAero
United States
Great info, thank you! Does anyone know if there is a MOST connector in the system anywhere? Does not appear to be one at this amp (same one as pictured above). I am integrating with my Meridian 16-ch surround system, and trying to avoid the complication of de-equalizing and summing the channels.
Post #1068911 1st Jun 2025 8:53pm
Fifth Horseman
None of the current Landrover audio systems use MOST. IIRC the last ones that did were the L319, L320 & L322 (D4, RRS & FFRR) and L405 up to about 2016 Defender 110 D300 X-Dynamic HSE MY22
Post #1068919 1st Jun 2025 10:35pm
