![]() | Home > Puma (Tdci) > Driver's door lock - whining/whirring |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 254 ![]() ![]() ![]() |
A few threads that might shed some light on the potential issues and help you solve your problem
https://www.defender2.net/forum/topic63776.html https://www.defender2.net/forum/topic56085.html https://www.defender2.net/forum/topic93413.html https://www.defender2.net/forum/topic92223.html Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
mptzs90 Member Since: 24 May 2024 Location: Kent Posts: 96 ![]() ![]() ![]() |
Thanks - I did search through but you've definitely found a couple of threads I didn't. sounds like I need to run through...
- Wiring (though perhaps unlikely since it's intermitting without movement) - Barrel lever frozen - Check fuses - though I'd assume a blown fuse would cause something to stop working completely vs being intermittent - Bunch of cleaning of the mechanism (I'll try WD40 all over them, wipe down and then silicone grease again) ... maybe this time I'll just completely disassemble and reassemble the mechanism to get it really clean ... - Remove the lock surrounds in case they're causing resistance (I don't think so because I have the same issue with the door card off) So of these... I'll check out the barrel lever and see what I find ++ clean it all out again, though I've done that once already. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
Just a small note to door lock cleaning - I made it on some cars without removing the lock from doors - it was sometimes succesfull sometimes not. After that, I have removed whole door lock from doors and bathed it in some brake cleaner and later in ultrasonic bath. There was allways huge ammount of dirt, old grease and metal particles washed away from the previously "cleaned" lock. After that and some lubing, locks were working better than new.
I think, to clean them propperly, removing from car is necessary. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
I disconnected the actuator from the mechanism and it still made the same whining/whirring sound intermittently. I've put a new actuator in now and it's working totally fine... so that rules out wiring/fuses. Will see... perhaps the last one just failed fast, or if this one fails fast then there might be something else going on - e.g. more resistance than usual which degrades them faster. Without the actuator attached, the door lock mechanism seems perfectly smooth to me using the key or the push switch.
Replaced the actuator and it's back to perfect. will see how long it lasts!
