Home > Puma (Tdci) > Driver's door lock - whining/whirring
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
2014 2.2 TDCI with central locking. When I either use the key in the barrel on the driver's side or use the remote, the driver's door sometimes whines and whirs before locking/unlocking. It's been doing this for a few weeks, no better after I tried to clean and lubricate the mechanism in the door (sprayed with silicone). Sometimes it works totally fine and then it won't lock or unlock at all for a few goes. The actuator was replaced with an (I think) genuine one about 16 months ago when it had the same symptoms and it's been fine for most of that time but it's now going again.
I've ordered another new, genuine actuator that I plan to fit myself in the next few days - but wanted to ask what might cause this issue in the first place? I assume the genuine actuators should last longer than this!? Are there other troubleshooting steps I could take to narrow down the problem? My worry is that this new actuator will also struggle in a few months for reasons unknown. Again... I'm assuming it's the actuator given that sorted it last time... but what else should I check?
thanks !
Post #1075601 17th Sep 2025 1:06pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
A few threads that might shed some light on the potential issues and help you solve your problem
https://www.defender2.net/forum/topic63776.html
https://www.defender2.net/forum/topic56085.html
https://www.defender2.net/forum/topic93413.html
https://www.defender2.net/forum/topic92223.html Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1075609 17th Sep 2025 3:02pm
mptzs90
Thanks - I did search through but you've definitely found a couple of threads I didn't. sounds like I need to run through...
- Wiring (though perhaps unlikely since it's intermitting without movement)
- Barrel lever frozen
- Check fuses - though I'd assume a blown fuse would cause something to stop working completely vs being intermittent
- Bunch of cleaning of the mechanism (I'll try WD40 all over them, wipe down and then silicone grease again) ... maybe this time I'll just completely disassemble and reassemble the mechanism to get it really clean ...
- Remove the lock surrounds in case they're causing resistance (I don't think so because I have the same issue with the door card off)
So of these... I'll check out the barrel lever and see what I find ++ clean it all out again, though I've done that once already.
Post #1075615 17th Sep 2025 3:43pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just a small note to door lock cleaning - I made it on some cars without removing the lock from doors - it was sometimes succesfull sometimes not. After that, I have removed whole door lock from doors and bathed it in some brake cleaner and later in ultrasonic bath. There was allways huge ammount of dirt, old grease and metal particles washed away from the previously "cleaned" lock. After that and some lubing, locks were working better than new.
I think, to clean them propperly, removing from car is necessary. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1075654 18th Sep 2025 8:23am
mptzs90
I disconnected the actuator from the mechanism and it still made the same whining/whirring sound intermittently. I've put a new actuator in now and it's working totally fine... so that rules out wiring/fuses. Will see... perhaps the last one just failed fast, or if this one fails fast then there might be something else going on - e.g. more resistance than usual which degrades them faster. Without the actuator attached, the door lock mechanism seems perfectly smooth to me using the key or the push switch.
Post #1075897 22nd Sep 2025 11:13am
mptzs90
Replaced the actuator and it's back to perfect. will see how long it lasts!
Post #1076696 2nd Oct 2025 9:33am
