Home > Td5 > TD5 in the States...what diff oil?
Mexirican007
United Kingdom 1999 Defender 110 Td5 CSW Cobar Blue
So oil is different than in the UK, so is there anyone that can point to a premium diff oil?
Post #1061931 4th Mar 2025 3:13am
landy andy
The diffs should have EP80/90 in them, and to be honest it’s not really worth mega high quality oils as they are basic old fashioned items. I go for more regular oil changes, than high very high spec oils. I assume your not running lockers or ATB’s which may alter oil type such as some ATB are mineral oil only.
I believe Americans call it 90 weight.
Post #1061936 4th Mar 2025 5:42am
Zed
I use Swepco which is from the States. 201 or 202 depending whether you have an ATB. WARNING.
Post #1062016 4th Mar 2025 9:53pm
Mexirican007
Thank you all, how about engine oil? ACEA A5/B5 is not easy to find and advertised for Euro gasoline cars.
Post #1062421 9th Mar 2025 3:45am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
That’s a really old standard and virtually any synth made today is compliant. I use Castol Edge Fully synth.
Good luck. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1062543 10th Mar 2025 6:18pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi,
Yes Castrol Edge here too, I have just ordered some 5w 40 for the first time as its getting older and in a mild tune.
A couple of points I can add is to be sure it has the 505.01 specification. This is required for Pumpe Duse engines 'PD' such ad the TD5 is.
Also make sure it is diesel engine compatible, it needs the extra additives to cope with all the extra soot which diesel engines get in the oil. We had a customer recently buying what they thought was diesel oil in the USA but did not have the additives required for diesel engines.
Post #1062553 10th Mar 2025 7:58pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
For towing and Hauling, 80w90.
Otherwise, 75w90 will work fine.
When the td5 came out it had an A1/B1 spec and this can mostly be found in 5w30 oils. A5/B5 is now successor of that spec but I am not a fan as it is a very fuel-efficient spec.
Almost all 5w30 specs have the ACEA A5/B5 spec.
I use, 5w40 with a A3/B4 Spec as this is a stronger oil and less likely to break down when working hard, or simply in stop and go traffic.
Post #1075424 15th Sep 2025 9:22am
adseybear
Canada
in Canada I'm running my Td5 on Rotella T6 5w40.
Meets all the heady duty diesel oil specs. Td5 was specced with a wide range of viscosities and A1/B1 is now an old spec and almost anything modern will outperform it.
Diffs get 80w90 GL-5 readily available. Although I just managed to get my hands on some Swepco 201. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #1075737 19th Sep 2025 3:59pm
