![]() | Home > Td5 > TD5 in the States...what diff oil? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
The diffs should have EP80/90 in them, and to be honest it’s not really worth mega high quality oils as they are basic old fashioned items. I go for more regular oil changes, than high very high spec oils. I assume your not running lockers or ATB’s which may alter oil type such as some ATB are mineral oil only.
I believe Americans call it 90 weight. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
I use Swepco which is from the States. 201 or 202 depending whether you have an ATB. WARNING.
This post may contain sarcasm. |
Mexirican007 Member Since: 30 Nov 2023 Location: Suffolk Posts: 20 ![]() ![]() ![]() |
Thank you all, how about engine oil? ACEA A5/B5 is not easy to find and advertised for Euro gasoline cars.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 991 ![]() ![]() ![]() |
That’s a really old standard and virtually any synth made today is compliant. I use Castol Edge Fully synth.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Hi,
Yes Castrol Edge here too, I have just ordered some 5w 40 for the first time as its getting older and in a mild tune. A couple of points I can add is to be sure it has the 505.01 specification. This is required for Pumpe Duse engines 'PD' such ad the TD5 is. Also make sure it is diesel engine compatible, it needs the extra additives to cope with all the extra soot which diesel engines get in the oil. We had a customer recently buying what they thought was diesel oil in the USA but did not have the additives required for diesel engines. ![]() |
