![]() | Home > Technical > Radio - no sound / no mileage display at ignition 1st pos |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21005 ![]() ![]() |
If you’ve had problems with multiple circuits, the common ground can often be a culprit.
So main ground between battery negative to both grounding points. This can be why fuses seem in-tact and no issues seem apparent, but there can be a significant voltage drop, and increase in current. The voltage drop can simply mean circuits don’t work as many need 9v plus to work, if the drop goes to day 5v due to high impedance ground, then that could be the issue. Especially Lilly if it’s multiple circuits at once, but if it’s a single circuit that there is a fault with then it the can be investigated further. The radio may display but not work if it sees below a certain voltage threshold, at its supply, that could be from voltage supply, but also from the negative side all the way back to common ground as explained above. Common ground issues can be common, if the vehicle has just came back from transmission works such as a clutch replacement, as the trans comes out sometimes and the grounding points get disconnected then refitted, sometimes they aren’t clean when refitted or not torqued, they can come loose as well. These are some suggestions, there’s nothing to say this is it but worth looking at. Loose battery clamps is also possible. There is the live side too, but I feel this is less likely. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
