![]() | Home > Maintenance & Modifications > Puma steering lock - how hard to change? |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
Easy to do, take off the steering column plastic shrouds to expose the lock. Removing the snap shear bolts is a bit of a chore; you will need a small pointed punch (though I have used a large nail instead) and a hammer. Position the punch on the bolt at about quarter past and gently strike in an upward manner with the hammer. Continue until the bolt moves, then unscrew it. You will need new shear bolts when installing. Make a note of the wiring before removing it, so you get it right when replacing the wiring For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 367 ![]() ![]() ![]() |
I installed that same kit a few months ago. It came with the steering lock cap and sheer bolts, which are not shown in that photo. Luckily I had my dashboard out so was easy.
EDIT: Hmm I've just checked Advanced website, and it looks like you are right. It all came in one box. So I must have ordered the cap and sheer bolts separately. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2524 ![]() ![]() |
See 6 posts down on this topic by member X4SKP for a how to with pictures https://www.defender2.net/forum/topic56773-45.html
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
Failing how? If its electrical connections (that the garage have cleaned) the switch can be changed without the lock mechanism, cheaper and easier......
HTH Keith |
If it is the switch that needs replacing as per Keith’s question above then member “The Anti Christ” posts a method of doing it without removing the ignition barrel 9 posts down in this topic https://www.defender2.net/forum/topic56773-60.html
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537 ![]() ![]() |
Much easier to remove dash if its a Puma, just buy a Genuine lockset they aren't that expensive .
