RobDefmanic
roche1800 wrote:And just to confirm there is power from the sensor back to ecu
I know it is a year ago, but i have the exact same problem. Needle on the dashboard dropped below the reading. Engine runs fine otherwise.
Did you fix the issue in your car?
9th Sep 2025 11:47am |
roche1800
I took the dash out and sent it off to be repaired/recalibrated at Remanx and that solved it.
9th Sep 2025 12:36pm |
