Home > Puma (Tdci) > Water Temp Gauge - not working
Page 2 of 2 <12
Check the plug on the rear of the instrument cluster isn’t loose or dislodged and general grounding on transmission is A1, plus that battery clamps are tight and battery voltage is in expected range.
For those that have a 2.4 Puma the CHT sensor is on the rear of the block, which is different to the 2.2.
The 2.4 requires a cut out socket that you can get to replace it as well, the socket for it is just under the engine cover and can be tested.
The 2.2 as has been mentioned is located in the location on pics above nearer the radiator in that hose, the part numbers for the 2.2 and 2.4 are different.
So just something to bear in mind.
Many faults are ground related, not always of course, loose connectors, a crack in a wire and more.
Ground faults being common can cause all sorts of random issues, as can voltage drop associated or a battery not in good state producing under voltage you never know but a Multimeter is a great too to sus out these things. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1045736 13th Sep 2024 1:21pm
RobDefmanic
Austria 2009 Defender 110 Puma 2.4 CSW Alpine White
Did you find a solution?
roche1800 wrote:
And just to confirm there is power from the sensor back to ecu
I know it is a year ago, but i have the exact same problem. Needle on the dashboard dropped below the reading. Engine runs fine otherwise.
Did you fix the issue in your car?
Post #1075099 9th Sep 2025 11:47am
roche1800
I took the dash out and sent it off to be repaired/recalibrated at Remanx and that solved it.
Post #1075103 9th Sep 2025 12:36pm
Page 2 of 2 <12
