Home > Puma (Tdci) > Diff lock won’t engage
Page 2 of 2 <12
CallumB
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Thanks for quoting what I already quoted.
Post #1043844 25th Aug 2024 5:01pm
Lady landy
Any joy sorting this out I’ve got the same issue
Post #1073821 20th Aug 2025 11:38pm
Ianh
Exactly this.
blackwolf wrote:
Usually this is because the selector mechanism has atrophied through lack of use and consequent lack of lubrication, but remedying it is not necessarily straightforward since it depends on which part has atrophied.
The first step is to get underneath and ensure that the external linkages are moving freely and fully. If they're not, you've probably identified the problem, and judicious application of lubricant and moving the linkage may solve it. If the external linkages are moving freely and fully and you still have no difflock, then it is overwhelmingly likely that the selector fork has seized on its shaft in the transfer box.
It is possibly (but extremely tricky due to poor access) to deal with this with the transfer box in situ if you remove the access panel (7 bolts on the nearside face of the front output housing of the transfer box) and lubricate the shaft and fork and manipulate the fork manually.
It is sensible to operate the CDL fairly regularly to make sure that it remains free and lubricated especially on vehicles which do low mileages.
Post #1073822 21st Aug 2025 12:33am
CallumB
Hi, are you referring to the lever in my 2.2 mot staying in position? If so, no, I haven’t. However, it does not effect the diff lock function. I even notice that the lever centres even when not in diff lock. I’ve assumed it’s just wear in the lever. My 2.4 does the same thing too now! To make matters worse on the 2.2 the diff lock light has also failed but the lock is still working!
Post #1073829 21st Aug 2025 8:13am
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I noticed as I was driving off the other day that the diff lock light had illuminated, maybe I knocked it or maybe not ... when I pulled it across to off and then checked it a few miles later I found it had crept back to more like the middle and it's doing that consistently. Is this normal? It hasn't re-locked (or at least the light hasn't come back on) since...
I've sprayed a bit of ACF-50 on it initially from underneath and plan to get some grease lubricant on there once it has dried. What's the best option? Copper grease / just WD40 ... or something else? And is the bit to get, the bottom of the long piece of metal as it enters the box? Looks like a couple of moving parts there though tbh they didn't seem very seized at all when I moved them so perhaps the moving to centre problem is unrelated.
Post #1074721 4th Sep 2025 1:41pm
Page 2 of 2 <12
