![]() | Home > Puma (Tdci) > Diff lock won’t engage |
CallumB Member Since: 22 Sep 2018 Location: Norfolk Posts: 88 ![]() ![]() ![]() |
Thanks for quoting what I already quoted.
Lady landy Member Since: 20 Aug 2025 Location: United kingdom Posts: 1 ![]() ![]() |
Any joy sorting this out I’ve got the same issue
Hi, are you referring to the lever in my 2.2 mot staying in position? If so, no, I haven’t. However, it does not effect the diff lock function. I even notice that the lever centres even when not in diff lock. I’ve assumed it’s just wear in the lever. My 2.4 does the same thing too now! To make matters worse on the 2.2 the diff lock light has also failed but the lock is still working! |
mptzs90 Member Since: 24 May 2024 Location: Kent Posts: 91 ![]() ![]() ![]() |
I noticed as I was driving off the other day that the diff lock light had illuminated, maybe I knocked it or maybe not ... when I pulled it across to off and then checked it a few miles later I found it had crept back to more like the middle and it's doing that consistently. Is this normal? It hasn't re-locked (or at least the light hasn't come back on) since...
I've sprayed a bit of ACF-50 on it initially from underneath and plan to get some grease lubricant on there once it has dried. What's the best option? Copper grease / just WD40 ... or something else? And is the bit to get, the bottom of the long piece of metal as it enters the box? Looks like a couple of moving parts there though tbh they didn't seem very seized at all when I moved them so perhaps the moving to centre problem is unrelated. |
