Home > Puma (Tdci) > Key Fob and immobiliser issue!
roche1800
Can anyone advise on this scenerio, I have a 2014 Defender which a bought a number of months ago. There is a list of jobs to do which I will be starting soon!
It started and drove with a damaged fob with the seller.
I have removed the battery and recharged it, refitted it and tried to de immobilise with the fob and new battery and it appears not connect to the vehicle.
Here is a photo with what I believe to be the correct set up to unlock - bottom 3 buttons and lock top 2 buttons.
Post #1074132 27th Aug 2025 10:37am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
There is a procedure to re-sync the fob with the vehicle after the battery has been renewed.
Post #1074172 27th Aug 2025 7:55pm
Ianh
With the doors shut click the lock button 4 or 5 times in quick succession, then click the unlock button once. This should then unlock the vehicle and sync the fob.
Post #1074189 27th Aug 2025 9:38pm
roche1800
Thanks, I have tried this and didn’t work. Any ideas please
Post #1074256 28th Aug 2025 2:08pm
Ianh
I’m assuming you have central door locking and it was working before.
Normally disconnecting the main starter battery does not cause an issue with loosing fob sync or needing the fob to be re registered with the 10AS. However if the fob is not working and won’t resync then the next job is to re register it to the 10AS or ALM unit. Speaking of which, what year is your defender as from circa 2012 the unit moved from the 10AS to the ALM CHxxxxx unit and the latter has a low starter battery brownout issue.
Do you have a Nanocom Diagnostic tool ?
Post #1074360 30th Aug 2025 12:03pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I don‘t quite understand. That fob on the photo is not original. Also you should have received two sets of key and fob.
Also door locking and immobiliser are two different systems, integrated in the same housing/fob/ALM.
Post #1074364 30th Aug 2025 1:48pm
Ianh
Hi macfrank I think the OP bought the vehicle used and was only provided with what he has shown.
And yes, well spotted, I did not really look but that’s not anything like the insides of a Lucas fob, and I’m pretty sure it’s not the insides of the Lear fob with the chrome strip that was used on the last defenders or as a replacement system for a faulty unit in the last couple of production years.
Roche1800, can you check what alarm unit you have, if genuine it will be fitted behind the drivers side front footwell speaker, removal of speaker provides access to it .
Post #1074392 30th Aug 2025 7:07pm
