![]() | Home > Faults & Fixes (L663) > Random selection of Low Range transmission |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 103 ![]() ![]() |
Does anything come up in the guage cluster? I've found that to engage low range you need to stop, go into neutral, press the button, wait, then set off. But from what you've described, it engages while you are driving I'd think that is a real problem. Does it shift gears alright? MY25.5 110 OCTA First Ed. P635
VeraDefender2025! Member Since: 14 Oct 2024 Location: Kent Posts: 2 ![]() ![]() |
Hi, when it happens, the gauge cluster says speed too high, stop and select neutral. Its behaving as if the low range button has been pressed whilst the car is in motion. The green low range indication on the gauge cluster remains flashing (as does the low range button itself) rather than going steady, presumably as the transfer box won’t engage because it has detected the car is in motion. The gearbox itself appears unaffected, the car drives normally in D or S mode as it did before this odd behaviour started and the transfer box correctly operates between high and low range as it should when the car is stationary and in neutral.
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 379 ![]() ![]() |
It seems obvious then that the switch is the one that fails! I think!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
![]() ExDiscovery 3 TDV6 SE |
If so that'll be a whole new switch panel, then, as that whole area is one piece.
![]() Click image to enlarge If you go to this page: https://parts.jaguarlandroverclassic.com/p...and-rover/ And click the little '+' next to "Heater Control (19A522A)" you'll be able to see all the variants of it and go through to find the assembly that best suits your vehicle description, then click the "+" again and see the part number. MY25.5 110 OCTA First Ed. P635 |
