![]() | Home > Maintenance & Modifications > UpGrading Washer Jets Puma |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
I fitted the optimil kit, works very well!
Not to bad to fit, around 2 hours 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| whitepeakwolf Member Since: 03 Feb 2021 Location: Peak District Posts: 44
Recently added a further standard washer fitting on the front of mine.
Blanked off the original centre placement & now have two in the blanked off holes for the LHD wipers. Pretty easy job & a game changer in the real world of insufficient coverage ! PS it’s a pre Puma Td5 |
| jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 222 |
How did you fit the passenger side washer? I had a look at doing this and it looked like the passenger side was blocked by stuff so access would have been a struggle...
Jonny - the faff was trying to change the original centre one, indeed I had to “modify” the centre dash top bracket to get it off. Don’t remember anything particularly challenging - just a little dismantling which was easy enough
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492
I am wondering why the squirters are not fitted on the hood. Is it the angle of the windshield or the fact the wipers are rather short.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17926
I think it has to do with legacy of a folding windscreen which makes bonnet (it doesn't have a hood!) mounted nozzles slightly unsatisfactory.
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 694
You can make big improvements fitting stronger pumps on the tank.
On my 110 I swapped the rear and front pumps and it made a notable difference as the rear one is stronger. I think a Discovery pump might be an option too. |
| SteveRat Member Since: 01 Aug 2012 Location: Chester Posts: 8
On my 300Tdi I fitted an extra standard jet on the front and moved the existing one over the drivers side. The holes were already there. Very cheap solution and works well. looks factory. Land Rover should have done it from the start.
| PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 196
Thanks for all the advice really appreciated
| Trev Member Since: 01 Jul 2023 Location: Fife Posts: 26
+1 for the Optimil kit. Expensive, but work brilliantly on my TDCI.
| MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 203
another alternative here :
https://csiparts.company.site/products/Ult...p632097361 or https://www.lrparts.net/lrc1411-ultimate-f...stock.html very happy with it - no need for stronger pump - just does what it says and much better that original. /Mat |
