Home > Maintenance & Modifications > UpGrading Washer Jets Puma
PWC1c
United Kingdom 2015 Defender 110 Puma 2.2 SW Auto Santorini Black
Hi
Thanks in advance .
Looking for advice on upgrading 2015 puma Front and rear washer jets for future proofing now the original system is 10 years old .
Post #1072433 29th Jul 2025 5:28pm
bear100
I fitted the optimil kit, works very well!
Not to bad to fit, around 2 hours 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1072461 29th Jul 2025 11:13pm
whitepeakwolf
Recently added a further standard washer fitting on the front of mine.
Blanked off the original centre placement & now have two in the blanked off holes for the LHD wipers.
Pretty easy job & a game changer in the real world of insufficient coverage ! Thumbs Up
PS it’s a pre Puma Td5
Post #1072479 30th Jul 2025 10:41am
jonny
How did you fit the passenger side washer? I had a look at doing this and it looked like the passenger side was blocked by stuff so access would have been a struggle...
Post #1072481 30th Jul 2025 11:07am
whitepeakwolf
Jonny - the faff was trying to change the original centre one, indeed I had to “modify” the centre dash top bracket to get it off. Don’t remember anything particularly challenging - just a little dismantling which was easy enough Thumbs Up
Post #1072485 30th Jul 2025 11:25am
MK
I am wondering why the squirters are not fitted on the hood. Is it the angle of the windshield or the fact the wipers are rather short. Rolling Eyes Puma 110" SW
Post #1072503 30th Jul 2025 1:26pm
I think it has to do with legacy of a folding windscreen which makes bonnet (it doesn't have a hood!) mounted nozzles slightly unsatisfactory.
Post #1072526 30th Jul 2025 5:33pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
You can make big improvements fitting stronger pumps on the tank.
On my 110 I swapped the rear and front pumps and it made a notable difference as the rear one is stronger.
I think a Discovery pump might be an option too.
Post #1072527 30th Jul 2025 5:44pm
SteveRat
United Kingdom 1995 Defender 90 300 Tdi CSW Arles Blue
On my 300Tdi I fitted an extra standard jet on the front and moved the existing one over the drivers side. The holes were already there. Very cheap solution and works well. looks factory. Land Rover should have done it from the start.
Post #1073878 21st Aug 2025 6:03pm
PWC1c
Thanks for all the advice really appreciated
Post #1073879 21st Aug 2025 6:21pm
Trev
Scotland 2008 Defender 110 Puma 2.4 USW Zermatt Silver
+1 for the Optimil kit. Expensive, but work brilliantly on my TDCI.
Post #1073896 21st Aug 2025 9:10pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
another alternative here :
https://csiparts.company.site/products/Ult...p632097361
or https://www.lrparts.net/lrc1411-ultimate-f...stock.html
very happy with it - no need for stronger pump - just does what it says and much better that original.
/Mat
Post #1074039 25th Aug 2025 2:29pm
