Home > Puma (Tdci) > Clutch went to the floor and stayed there
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
So a couple of years ago my clutch failed on the M1 - pedal went to the floor and wouldn't come up.
Local independent replaced clutch, bearing and slave, and I replaced the master cylinder - all good
A few days ago was moving it about 20 meters to clean the driveway and clutch went down and stayed there - had to pull up by hand. Was fine after that but clearly there is a problem.
Haven't had a chance to check the master for fluid level but is this a case of cooked slave or master cylinder?
Post #1073856 21st Aug 2025 1:12pm
TexasRover
On Td5 and beyond there is a spring installed on the clutch pedal on the inside (cabin side). It overcenters and ensured the pedal stays positively up at rest, yet provides and assisting force at the downwards stroke to make the clutch lighter.
If your pedal is not correct adjusted the overcenter spring can prevent the pedal from coming up especially if you clutch is a bit on the light side, has some air inside or the overcenter spring is a bit too heavy (LOF does a beefed up green version).
You might want to check if the system needs a bleed or if pedal movement (stops) is within the documented setting and adjust the bottom stop.
There recently was a discussion here where the whole mechanism and it's function was discussed in detail
Post #1073867 21st Aug 2025 4:15pm
kmac
Thanks will have a search for the discussion you mention
Post #1073900 21st Aug 2025 10:39pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Start with the obvious and check the clutch fluid level. A failing master cylinder can also do this with no fluid loss.
Post #1073915 22nd Aug 2025 1:41pm
It could be the MC, but more likely the slave. Usually is, as it’s the most likely to be a pain. Rolling Eyes ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073920 22nd Aug 2025 2:28pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
I bought a vehicle with the clutch pedal on the floor.
It was the pedal seized on the shaft it pivots on.
Oiled it and moved it up and down for a while. Been great ever since, 4 years now. 😉
Post #1073930 22nd Aug 2025 7:36pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Clutch went to the floor and stayed there
Same issue, few months ago : Master cylindre. Liquid level remainrd unchanged.
Post #1073945 23rd Aug 2025 9:39am
