![]() | Home > Puma (Tdci) > Clutch went to the floor and stayed there |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1331 ![]() ![]() ![]() |
On Td5 and beyond there is a spring installed on the clutch pedal on the inside (cabin side). It overcenters and ensured the pedal stays positively up at rest, yet provides and assisting force at the downwards stroke to make the clutch lighter.
If your pedal is not correct adjusted the overcenter spring can prevent the pedal from coming up especially if you clutch is a bit on the light side, has some air inside or the overcenter spring is a bit too heavy (LOF does a beefed up green version). You might want to check if the system needs a bleed or if pedal movement (stops) is within the documented setting and adjust the bottom stop. There recently was a discussion here where the whole mechanism and it's function was discussed in detail |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Thanks will have a search for the discussion you mention
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 268 ![]() ![]() ![]() |
Start with the obvious and check the clutch fluid level. A failing master cylinder can also do this with no fluid loss.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
It could be the MC, but more likely the slave. Usually is, as it’s the most likely to be a pain.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344 ![]() ![]() ![]() |
I bought a vehicle with the clutch pedal on the floor.
It was the pedal seized on the shaft it pivots on. Oiled it and moved it up and down for a while. Been great ever since, 4 years now. 😉 |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Same issue, few months ago : Master cylindre. Liquid level remainrd unchanged. |
Mago Member Since: 25 Apr 2021 Location: Frankfurt Posts: 41 ![]() ![]() |
If the fluid level in the reservoir has dropped, it might also be worth taking a look at these two parts:
![]() Click image to enlarge Valve 18 (UUG500040) broke in my case once, and the clutch pedal simply got stuck on the floor. The fluid leaked out of this valve. ![]() Defender 110 Puma 2.4 |
