Home > General & Technical (L663) > Warped brake discs
lightning
Warped brake discs
So l have had the symptoms of warped brake discs for ages, pulsating brake pedal when slowing from higher speeds and a similar feel to the vehicle as it slows down.
My question is, which brake discs are most likely to have warped. l've got a spare front set and was hoping it was the front! They seem easy enough to change unlike my old Defender where you have to remove the wheel hub and bearings.
Post #1073425 15th Aug 2025 4:07pm
LandyMax
I had the same symptoms on my first Defender and Disco 5, in both instances new front brake discs resolved the issue.
Post #1073428 15th Aug 2025 4:25pm
keith
I also have had the brake pedal pulse back and was told that the discs were prone to warping. Replaced the calipers with new stainless pistons and that fixed the problem. I did have a thought that the pulsing may have been a stuck piston and it was.
Post #1073434 15th Aug 2025 5:06pm
lightning
Okay thanks l will change the front discs and check the calipers at the same time.
Then if the fault remains, at least l will know what it isn't.
Post #1073438 15th Aug 2025 5:48pm
lightning
l replaced the discs this afternoon and the fault seems to have disappeared so it must have been the front.
A bit of advice if you plan to change the discs/pads
The two bolts holding the caliper are very tight and you'll need an 18" breaker bar to get them off. The small allen head bolt holding the disc on is made of cheese and if you try to use an allen key on it, the head will strip.
What you need to do is centre punch the edge and tap it loose. Then you can use an allen key on it.
The brake caliper is very heavy and it goes without saying that you must not let it hang on the flexible brake hose. l used a bungee cord to hold it out of the way. Have it ready for when you take the bolts out.
Post #1073513 16th Aug 2025 7:54pm
The_75th
Just to jump on this - warped discs aren't really a thing. It's a term often bounded around by luddite mechanics.
It's also a way that garages can blame the user for overheating brakes to get out of any warranty claims.
What you have experienced is pad material transfer, usually because the pads, when new, weren't bedded in correctly.
https://www.brakes-shop.com/brakepedia/gen...ing-system
One used to get a little leaflet with a set of brake pads, explaining the bedding in process. But that has gone the same way as the still critical "running in" oil change at 2K.
General brake pad bedding in guide:
https://www.dcperformance.co.uk/pages/ebcbeddinginprocess.html
Post #1073675 19th Aug 2025 12:28pm
Can_glu
Canada
Your experience is of great value to our DIYers. Could you please give a bit more details on how you got these bolts off?
Thanks from Canada
Post #1073755 20th Aug 2025 10:10am
lightning
That's very informative, l definitely didn't follow this procedure when l bought the vehicle, l just drove it normally.
Post #1073786 20th Aug 2025 5:19pm
lightning
"Your experience is of great value to our DIYers. Could you please give a bit more details on how you got these bolts off?
Thanks from Canada"
I just used a socket (21mm) with an 18" socket wrench (generally referred to as a "breaker bar" in the U.K.)
to initially loosen the bolts and then was able to use a standard ratchet wrench to fully remove them.
Post #1073788 20th Aug 2025 5:24pm
mse
Thanks from Canada
No way my big breaker bars on stands would touch it, maybe if I was underneath o a lift. But my 1000 impact after 5 minutes got them off,
As mention the retaining screws were never going, one bit sheared and the other rounded…I punched them, dealer had the bolts on the shelf, very common so just have it all ready Mike
Post #1074384 30th Aug 2025 6:20pm
lightning
Breaker bar shifted the bolts but only with my full weight on it....difficult to do as it only just fitted under the wheel arch and then had to keep
moving it slightly to enable more movement of the bolts.
EDIT my mistake.....24" breaker bar.
Post #1074385 30th Aug 2025 6:23pm
mse
I had one of those, couldn’t get the scaffold pole on it…but then it was only on stands and I think 3.5yrs old.
But work smarter, I got my big impact on the 4 of them Rolling with laughter Mike
Post #1074389 30th Aug 2025 6:37pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
raising the truck will give you better room, breaker bar as shown will crack the bolt, then followed by a half of quarte inch drive to expedite quicker followed back by the breaker bar, otherwise a quarter inch drive attached with a pipe at the end, never had an issue removing it but patience's is key, it will go....
if you're really having trouble, breaker bar followed by locking pliers..... you can reuse the bolts just coat the head with some copper grease
80nm is the torque spec. dont forget your loctite. they will come loose, I put my word on that
the cause of the warpage is either the rotors are too thin or most likely your pistons in your caliper are seized. can go for stainless steel which I didn't because I prefer to rebuild my calipers every 3-5 years to get the crud out of the caliper bore
Best way to not have this happen is drive the truck Very Happy
Post #1075893 22nd Sep 2025 8:54am
