![]() | Home > Modifications & Maintenance (L663) > 2024 Defender D250 - service intervals |
Landy240 Member Since: 22 Jul 2024 Location: Merseyside Posts: 27 ![]() ![]() |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3314 ![]() ![]() |
You can get the oil changes when the vehicle demands it. Whether or not it's replaced again at the service interval will depend on how long it it since it was changed. So if your Defender demands an oil change at 12,000 and then the two year service is at 15,000 they probably won't change the oil again and it's only done 3,000 |
Yes, that was how I understood it and was going to approach it.
What is a bit odd to me is that why my service sheet doesn't mandate an oil change at service time but the sheet posted by L3785 does. We both have the same engine I think, & I am guessing that we all have the ECU countdown to oil change in the service menu. It doesn't really matter as I'll be going off what the ECU dictates or better anyway, but it does explain some of the confusion on this thread and the similar thread in 'general and technical' [/quote] |
L3785 Member Since: 08 Oct 2024 Location: Yorkshire Posts: 56 ![]() ![]() |
I wonder whether it’s taken into account that you’ve already done an oil change and therefore won’t mandate it at the service? (Whereas I’ve not yet changed the oil as I’ve only done 6,500 miles so far.)
Although, even if it is that, it’s strange for it not to be standardised (especially if the service cost would be the same for us both!!!) 2025MY Defender 90 D250 X-Dynamic HSE | Santorini Black with Black Pack |
