Home > Puma (Tdci) > 62 plate with new engine, turbo and injectors: loss of power
Page 2 of 2 <12
roche1800
Is it these sensors to remove???
Post #1073165 11th Aug 2025 2:14pm
roche1800
The function to upload a pic has gone
Post #1073166 11th Aug 2025 2:16pm
No it hasn't! Very Happy
(Random picture to prove a point)
Post #1073168 11th Aug 2025 2:31pm
roche1800
Here are the pics, the feature wasn’t there a few mins ago!!
Post #1073170 11th Aug 2025 2:36pm
MK
The one in the top must be the oxigen sensor. Plus 3 more down the pipes which are probably temperature probes. To the best of my knowledge. In theory they should be removable. Puma 110" SW
Post #1073171 11th Aug 2025 2:44pm
andy63
You shouldn't need to touch any of the 3 temp sensors..in fact they can be difficult to remove even with the pipe off the vehicle..
Look back at my earlier photo..its not great but you can see the differential pressure sensor connections..and I've already explained how I think you best go about checking they are clear..
Post #1073178 11th Aug 2025 3:45pm
roche1800
With this hot weather the popping has decreased massively but the DPF light came on again and then went off after a high rev drive round the lanes.
Is it now time to remove the DPF and have it professionally cleaned.
Post #1073368 14th Aug 2025 1:32pm
andy63
So your dpf light is coming on but you still haven't said if you checked the sensor pipes or indeed got a figure for the differential pressure to confirm it warrants a fault light..
Suspect if you take it somewhere to be done they would at least confirm this before attempting a clean..
I also wouldn't be surprised if they also tell you it can be cleaned in siteue, cause they are a pill to get out, certainly from below.. I think I've seen reference to it been removed out the top which likely saves getting to engine mounts on that side.
Good luck with it and look fwd to hearing how it goes..👍
Post #1073370 14th Aug 2025 2:03pm
Page 2 of 2 <12
