Home > Td5 > TD5 coolant/overheating
CdnGriff
Canada 1999 Defender 90 Td5 CSW Keswick Green
Hi, new owner, old TD5
1999 D90 in Canada, 250k km
Drove well for first week, then it suddenly lost power and temp gauge pegged into red. No warning.
Let it cool, got it home. Did it again.
Checked coolant, hoses, etc.
Now if I turn key, temp gauge immediately goes into red despite not being run in over a day.
Thermostat? Electrical fault?
Any help appreciated.
Total amateur and newbie.
Post #1072313 27th Jul 2025 7:45pm
landy andy
Electrical fault. Check wiring underseat fuses, and check earth connections in same area. Even use a jump lead battery negative to underseat area, and, or bulkhead.
Post #1072317 27th Jul 2025 8:27pm
jst
Check battery earth strap. I would remove chassis end and clean up and refit. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072321 27th Jul 2025 9:23pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
What they said plus it’s a good idea to run a ground cable from the casing of the ECU direct to the negative battery terminal. My temperature gauge would often ‘spike’ into the red momentarily and lose power. Never done it since I grounded the ECU casing. I’m saying grounded when I really want to say earthed, but I’m trying to speak a bit of Canadian.
Post #1072324 27th Jul 2025 10:47pm
TexasRover
Side note, but I believe grounding to be the more appropriate term especially since a car on rubber wheels has little connection to Earth. It's obviously the negative battery terminal that is connected to all all the other negatives (zero potential between them). According to AI both terms are not the most suitable
Earthing
Earthing refers to connecting a circuit directly to the ground.
It protects against electrical spikes and potential damage to life and property.
The wire used for earthing is typically green in color.
Grounding
Grounding means creating a zero potential in a circuit without a direct connection to the ground.
It provides insulation against accidental currents and helps prevent overloads.
The wire used for grounding is usually black in color.
Post #1072329 28th Jul 2025 8:18am
CdnGriff
Thanks to all for the suggestions.
Trying to chase the electrical fault now. There are many many added on wires and bits in this thing.
I also may have the “oil in the ECU” problem, the wiring is pretty oily. Is that just an extra problem or is it possibly the fault?
Feel free to talk to me as one who needs things explained slowly and with crayons.
Cheers,
Post #1072399 28th Jul 2025 11:56pm
CdnGriff
I’ve cleaned up all the wiring, checked the earth strap, ran a jump lead from earth point in ECU box to the battery, still same fault.
Does the ECU “casing” mean the underseat cubby/box?
Willing to try anything at this point.
Post #1072496 30th Jul 2025 12:44pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Where are you in Ontario? I am in Ottawa, happy to assist and we can scan with my Nanocom and see what’s up. Also suggest joining Ottawa Valley Land Rovers on FB (largest and oldest Land Rover club in North America). If you do join the FB group post this issue, lots of us here in Ontario with Td5s. I might be able to hook you up with someone nearby to assist you if you are not on FB.
Definitely clean up that oil in the red ECU plug use electrical cleaner or brake cleaner and dry it out. And change the injector harness. ECU casing being referring to is the silver box under the seat. Use one of the bolts securing it as a ground wire anchor. Feel free to PM me off line if that is easier…
Good luck 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1072521 30th Jul 2025 4:03pm
CdnGriff
Thanks!
I’m in Kingston, so not very far, but far enough at this point.
I will look up the Ottawa group.
I did clean out the ECU and connector and will get on the harness swap; not sure that will fix current problem.
I will certainly reach out to you later.
Thanks again
Post #1072523 30th Jul 2025 4:21pm
4RF RDS
That will not affect the overheating issue but needs attention for sure. Parts availability in Ontario for Td5 is great at 3Brothers Classic Land Rovers in Paris (near Hamilton). We have a several members in and around K-town. I’ll look in the club database to see if anyone has a Td5.
https://3brothersclassicrovers.com/
https://ovlr.ca/
Stay in touch.
Cheers 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1072524 30th Jul 2025 4:32pm
CdnGriff
Thanks for everyone’s suggestions and help.
After 4 weeks in a garage tracing everything we could think of … it’s a faulty inertia switch. That’s it.
Anyway, add that to the list of TD5 lore.
Post #1074122 27th Aug 2025 12:09am
rustandoil
Well done!... Inertia switch, that's a problem I've not heard of before.
Hopefully you can enjoy your TD5 trouble free for a while now 👍🏼
Post #1074125 27th Aug 2025 6:31am
jst
Inertia switch, not heard of that failing casuing that problem before. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1074128 27th Aug 2025 8:12am
Rob19321
Canada 2004 Defender 110 Td5 CSW Alpine White
Re: TD5 coolant/overheating
Hi, just hello from another Canadian!
Rob in Halifax Hmmm, these are tough for me.
Old guy now, knocking items off a bucket list I suppose.
In signing up, I chose "Country Station Wagon" and "Alpine White" but I don't know for sure.
Post #1074241 28th Aug 2025 11:56am
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
if your going to the british car show on 21st in oakville, I will be there with my td5, I can take a look for you
Post #1075417 15th Sep 2025 7:59am
