Home > Td5 > TD5 coolant/overheating
CdnGriff
Canada 1999 Defender 90 Td5 CSW Keswick Green
Hi, new owner, old TD5
1999 D90 in Canada, 250k km
Drove well for first week, then it suddenly lost power and temp gauge pegged into red. No warning.
Let it cool, got it home. Did it again.
Checked coolant, hoses, etc.
Now if I turn key, temp gauge immediately goes into red despite not being run in over a day.
Thermostat? Electrical fault?
Any help appreciated.
Total amateur and newbie.
Post #1072313 27th Jul 2025 7:45pm
landy andy
Electrical fault. Check wiring underseat fuses, and check earth connections in same area. Even use a jump lead battery negative to underseat area, and, or bulkhead.
Post #1072317 27th Jul 2025 8:27pm
jst
Check battery earth strap. I would remove chassis end and clean up and refit. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072321 27th Jul 2025 9:23pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
What they said plus it’s a good idea to run a ground cable from the casing of the ECU direct to the negative battery terminal. My temperature gauge would often ‘spike’ into the red momentarily and lose power. Never done it since I grounded the ECU casing. I’m saying grounded when I really want to say earthed, but I’m trying to speak a bit of Canadian.
Post #1072324 27th Jul 2025 10:47pm
TexasRover
Side note, but I believe grounding to be the more appropriate term especially since a car on rubber wheels has little connection to Earth. It's obviously the negative battery terminal that is connected to all all the other negatives (zero potential between them). According to AI both terms are not the most suitable
Earthing
Earthing refers to connecting a circuit directly to the ground.
It protects against electrical spikes and potential damage to life and property.
The wire used for earthing is typically green in color.
Grounding
Grounding means creating a zero potential in a circuit without a direct connection to the ground.
It provides insulation against accidental currents and helps prevent overloads.
The wire used for grounding is usually black in color.
Post #1072329 28th Jul 2025 8:18am
CdnGriff
Thanks to all for the suggestions.
Trying to chase the electrical fault now. There are many many added on wires and bits in this thing.
I also may have the “oil in the ECU” problem, the wiring is pretty oily. Is that just an extra problem or is it possibly the fault?
Feel free to talk to me as one who needs things explained slowly and with crayons.
Cheers,
Post #1072399 28th Jul 2025 11:56pm
