![]() | Home > Wheels & Tyres > The Wolf steel wheel appreciation thread |
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 97 ![]() ![]() ![]() |
Dear wolf appreciation society …..
I am trying to find pictures of a white 110 CSW or XS puma with white wolf wheels. You would think it would be easy but I am failing so far. If anyone has one and has a few photos would like to see if white on white is too much. Thanks in advance. 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
allybee73 Member Since: 31 Aug 2016 Location: Essex Posts: 23 ![]() ![]() |
This any use?
https://www.ebay.co.uk/itm/296959958439 |
perfect
good man. thanks for that 2010 90 LHD soft top 2010 110 XS 2008 110 E LHD 1985 90 soft top |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1092 ![]() ![]() ![]() |
White on white looks absolutely gorgeous! 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
Go on then …. Tempt me. Do you have any photos? 2010 90 LHD soft top
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3635 ![]() ![]() ![]() |
I think there are many with the standard white steel rims, which would not look too different from the wolfs. But maybe this helps to visualize: https://www.alamy.com/stock-photo/white-la...y=relevant 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 788 ![]() |
Not a CSW but our Dormobile has white on white.
Thanks all 2010 90 LHD soft top
PauloA Member Since: 29 Apr 2024 Location: Bristol Posts: 40 ![]() ![]() ![]() |
Finally got my Wolfs (and new tyres) fitted today and I love how they look. The whole Landy is a work in progress but at least the wheels are now how I want them
![]() ![]() Click image to enlarge Cheers, Paul |
whitepeakwolf Member Since: 03 Feb 2021 Location: Peak District Posts: 49 ![]() ![]() |
I happen to have a spare set of Wolf wheels for refurb . . . & my current steeliest are untidy
![]() Any pics of a similar truck ie Belize Green with black arches wearing Wolf wheels ? Thinking of getting them painted body colour ![]() ![]() Click image to enlarge |
Nooooo - white wolfs to match the roof! 2017 5.0 V8 Supercharged RRS SVR
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 537 ![]() |
Nooooooo, body colour Wolfs look
Far far better 😊 |
white_defender90 Member Since: 04 May 2022 Location: Manila Posts: 1 ![]() ![]() ![]() |
Sharing my 90. Been with the family since 1997. Under my care since 2009. It was a pick up until 2020 when I converted it to a station wagon.
***ooops looks like my attached file was not upleaded |
Beco90 Member Since: 10 Jul 2024 Location: South Wales Posts: 39 ![]() ![]() |
Hi all, I picked up a set of genuine Wolf wheels at the LRM Malvern show last October which I finally got round to painting a limestone and am now ready to fit. They will be going on my 2012 110 station wagon which currently has a set of Boost alloys.
As I’ve read over and over, the Wolf wheels are significantly heavier than the boost alloys. What differences have others noticed when switching from Boosts to Wolfs? Is there a noticeable deterioration in ride, or steering feel and braking for example? Depending on the source, Wolfs seem to be quotes as about 3 to 4 kg heavier per corner. Some people say they weigh as much as 17 kg, whilst Boosts seem to weigh around 13 to 14 kg. This seems like a significant increase in unsprung weight. Obviously I love the Wolf look, but I’d like to hear if anyone else has any regrets from making the switch? I’ve spend quite a bit of cash getting the ride on my 110 more comfortable and the steering tight as it should be from the factory so don’t want to undo my efforts so far! Are there any other downsides I should be aware of (apart from the need to change the wheel nuts and the length of the wheel bolts) that I should be aware of? Also - the Wolf copies all seem to have a lower load rating. Is this because they are made of thinner steel and are therefore lighter than the genuine Wolfs? Cheers all! |
