![]() | Home > Td5 > Aux belt pulley bearings |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 218 ![]() ![]() ![]() |
Hey Folks,
Started getting 'the whine' a few weeks ago, which is getting worse. I pretended I had a Supercharger for a bit then grew up and decided to sort it. I removed the viscous fan and aux belt then started spinning things; Tensioner pulley rough but also BOTH idler/ guide rollers at the top, nearside of the block. Did a quick Google and forum search and it looks like I have to replace the tensioner but what about the top two..?? Can I fit new bearings and does anyone know what size I need..?. Thanks in advance. Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Thanks John - i've got a new belt to fit.
The three pulley/idlers in question are rough and rumble when spun. They definitely need replacing. I was hoping somebody had the sizes to hand so that I can order them and do the job on the second visit. Experience tells me that if I don't finish a job it tends to stay nearly finished for ever... ![]() 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
IIRC I think Goebloke did replace the bearings and supplied part numbers. I don’t think he’s posted for a while. Think you might find it in his lengthy build thread, pm him or do a “search” I’m 99% sure the info is on this forum somewhere.
I just replaced them all with new ……. |
Quick search threw up this, not the bearings, but replacements, but I know I read about replament bearings somewhere
![]() Quick update on this, the workshop have looked at this and advised the idler pulleys are at fault / 'worked'. Service advisor did not state which specifically. Similarly advised the aux belt and tensioner could do with a replacement. They are fitting ALLMAKES parts: -ERR6493 IDLER-TIMING BELT -ERR6658 IDLER - ANCILLARY -ERR6951G TENSIONER-TIMING BELT -PQS101490D DRIVE BELT - AUXILIARY - TD5 I did ask for JLR genuine items, however was shortly advised not available from them any longer. They have assured me these are high quality. After checking with them, it appears the Aux Belt & Tensioner are All Makes OEM, whilst both Idler's are All Makes aftermarket as advised not otherwise available |
Thanks Jim - that's great info and gives me a place to start the search.... (The original post that you quote refers to 'timing belt' - I'm assuming that's some kind of autocorrect thing kicking in..?? My phone changes things without asking me - the machines are taking over..!!!! 😄).
I'll remove the Idlers and measure up the bearings and post on here - might help somebody in the future.. 👍👍 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
I replaced a few too many of these so I can't recall what the td5 has, but the plastic ones you have to buy new as the bearing cannot be replaced. The metal ones you can push out and push in the bearings (a set of two I recall).
I have actually been hoarding the metal ones as you can often replace the plastic one with the metal one and I prefer to buy high quality bearings, rather than rely on the manufacturer to choose for me. Realistically though unless you do a lot of miles whatever bearing you have will last a while and they are easy enough to diagnose and replace again if you find you received a dud. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Does this help?
https://www.defender2.net/forum/topic90090.html?highlight=bearing 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
That's the badger..!!
Absolutely perfect - thank you 😁 I've just removed the two top idler pulleys and can confirm that they both have the same bearing fitted - NTN 6303 LHA. Just had a go at knocking one out (coulda phrased that better 😀). Bloody hell - they're in there tight. Might need a press. Can anyone recommend a good make of belt tensioner..?? They are not easily refurbished so I'll just buy one of these and a couple of bearings for the idlers. Prices vary from £25 to £125 for the tensioners.... Thanks for all the help - it really is appreciated. Cheers, Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
![]() Knock one out....haha Main LR dealer is where I got mine from - Duckworths from this forum. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Knew I’d seen it somewhere ![]() ![]() |
Thanks, as always, for your help 👍
Just in case it helps anyone else, this is what I've done/am doing; ![]() Click image to enlarge Auxiliary Belt (non AC) = PQS 101490 Belt Tensioner and Pulley = ERR 6951 ( not easily refurb'd) Idler Pulley (inner) = ERR 6493 (about £60) Idler Pulley (outer) = ERR 6658 (about £35) Or you can just replace the bearings in both Idler Pulleys - same bearing in each; OE = NTN 6303 LHA Quality equivalent = Timken 6303 2RS/C3 or SKF 6303 2RSR C3 I've gone for a pair of SKF @ £11 for the two. Now, there isn't much land with which to drive the old bearings out: ![]() Click image to enlarge The diameter of the hole in the pulley is about 41.7mm so you'll need something about 41mm to knock the old ones out. Hope this helps. Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Hiya,
I was really hoping that this 'topic' could have ended here, but..... New bearings fitted to Idler pulleys, idler pulleys refitted, new Tensioner assembly fitted and new belt fitted. Before I refitted the fan I started the engine, and although quieter, it's still making a noise. As the fan wasn't fitted it was easier to pinpoint where the sounds is coming from. The noise sounds like it's coming from the Alternator. Could it be a bearing in the Alternator or maybe something from the Vacuum side..?? Anybody had a noisy Alternator before..?? it's still charging fine. I'm driving to northern Germany in it in a few weeks so need this sorting... ![]() Cheers, Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Remove belt and start the engine and see if the noise has gone?
My issue after chasing similar turned out it was the belt. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Hi John,
I fitted a new belt (Dayco) and it's still noisy. I'll try the Britpart belt that I carry in the under seat 'spares box'. Fingers crossed,... Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
