Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod!
Page 3 of 3 <123
I’m not sure what size it was, but the grease nipple I put in there was the same as the UJ’s if I remember rightly.
You can soon tell as if there is a thread there it will screw in with finger tips.
It’s definitely small and only the coupler nipple. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027670 11th Mar 2024 8:13pm
Ianh
I can confirm that you require a 1/4" UNF and not 6mm grease nipple as I ordered a 1/4" UNF 90 degree nipple and fitted it. The thread “felt” exactly right as I screwed it in by hand and nipped up with a spanner. Noting if it’s pointing the wrong way when tight , as mine was, you can use a 6mm flat washer to pack out and get it to point in the correct direction once tightened.
Many thanks to Blackwolf for investigating and highlighting the correct size and thread within the shaft.
Edit: when I said 6mm washer I meant an M6 washer . My grease nipple was about 180 degrees out, I.e pointing towards the lower end of the bulkhead, the M6 washer was approx 1mm thick and allowed the nipple to face forward and up when tight. The perfect position to couple to the grease gun.
Post #1035510 23rd May 2024 7:56pm
Dinnu
If the 90degree grease nipple ... 1/4"UNF has 28TPI, converting into metric, pitch is about 0.9mm. So if you can find a 0.50mm thick washer, the grease nipple might end up facing the direction you would certainly prefer.
I have an M6 grease nipple waiting to go in Whistle Not too worried, its a relatively short thread, and only need to go in 1 time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1035536 24th May 2024 6:29am
khamuul
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
Fitted a 1/4" 90 degree grease nipple on my LHD puma. Thanks for sharing! Thumbs Up
Post #1037566 15th Jun 2024 11:07pm
johnnymarrsbarres
 2007 Defender 90 Puma 2.4 SW Cairns Blue
Hi all
Tried this mod on my 2.4 TDCi to try and get rid of the squeak.
Still squeaking after I’ve taken the top plate off and blasted it with everything from WD40, silicone spray and added a grease nipple and given it a few pumps of grease.
Weirdly it only squeaks after about 45 mins or so of driving. Could be heat related?
Driving me bloody mad! Any suggestions?
Post #1071560 16th Jul 2025 11:02am
LR90XS2011
try lubricating the points on the clutch pedal where the return spring is in the footwell, wd40 isn't a great long term lubricant as it dries out, a spray grease would be more suitable DEFENDER 90 TDCI XS,
Post #1071603 16th Jul 2025 9:12pm
Page 3 of 3 <123
