![]() | Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod! |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2507 ![]() ![]() |
I can confirm that you require a 1/4" UNF and not 6mm grease nipple as I ordered a 1/4" UNF 90 degree nipple and fitted it. The thread “felt” exactly right as I screwed it in by hand and nipped up with a spanner. Noting if it’s pointing the wrong way when tight , as mine was, you can use a 6mm flat washer to pack out and get it to point in the correct direction once tightened.
Many thanks to Blackwolf for investigating and highlighting the correct size and thread within the shaft. Edit: when I said 6mm washer I meant an M6 washer . My grease nipple was about 180 degrees out, I.e pointing towards the lower end of the bulkhead, the M6 washer was approx 1mm thick and allowed the nipple to face forward and up when tight. The perfect position to couple to the grease gun. Last edited by Ianh on 24th May 2024 11:14am. Edited 1 time in total |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
If the 90degree grease nipple ... 1/4"UNF has 28TPI, converting into metric, pitch is about 0.9mm. So if you can find a 0.50mm thick washer, the grease nipple might end up facing the direction you would certainly prefer.
I have an M6 grease nipple waiting to go in ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 27 ![]() ![]() ![]() |
Fitted a 1/4" 90 degree grease nipple on my LHD puma. Thanks for sharing!
![]() ![]() Click image to enlarge |
johnnymarrsbarres Member Since: 03 Oct 2024 Location: UK Posts: 50 ![]() ![]() ![]() |
Hi all
Tried this mod on my 2.4 TDCi to try and get rid of the squeak. Still squeaking after I’ve taken the top plate off and blasted it with everything from WD40, silicone spray and added a grease nipple and given it a few pumps of grease. Weirdly it only squeaks after about 45 mins or so of driving. Could be heat related? Driving me bloody mad! Any suggestions? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
try lubricating the points on the clutch pedal where the return spring is in the footwell, wd40 isn't a great long term lubricant as it dries out, a spray grease would be more suitable DEFENDER 90 TDCI XS,
