Home > Puma (Tdci) > 2.4 minor overhaul
Likeomg
2.4 minor overhaul
Hello all,
I have decided to do a mini refresh on my 2.4 Puma, it has circa 90k miles on it now gets serviced probably every 3-5k miles (i work 10/10 offshore and have place in the USA now so rarely in the UK)
It was previously tuned with Hybrid turbo, intercooler, straight through exhaust stainless boost pipes etc.
I know the common census now is hybrid turbo's are no better than standard, i have also noticed a fair bit of smoke lately and don't ever think i had much luck with this hybird turbo.
I was in touch with Alive and they want ~£2500 for supply / fit of a standard turbo, am i missing something? what is the current correct part number for a defender 2.4 standard turbo? LR018396
LR018497?
I'm completely fine with doing the turbo myself..
JLR have them at £2300 elsewhere online reputable sellers have them in the 7-800 mark? where is the best to buy them from? are the ones on LR parts / Island4x4 the same as the classic Land rover ?
I will also fit new oil pipes at the same time, what else would be worth while doing VCV? Any other suggestions?
I will bolt it all on myself and drive down to alive for the tuning to be re-done for a standard turbo and checked out
I also don't want to spend an absolute fortune on it doing injectors etc as i might as well buy a M57 conversion etc...
Liam
Post #1071515 15th Jul 2025 6:53pm
hank
Turbo Technics sell brand new Garrett units for a very good price. I had one off them a couple of years ago > 110 XS Double Cab
Post #1071517 15th Jul 2025 7:04pm
Likeomg
Hi Hank, and they are the same as what JLR classic are selling or am i msising something?
Alive stated they would only fit "genuine" turbos so that means JLR pricing? or am i missing something?
Post #1071518 15th Jul 2025 7:07pm
BrickBox
That’s an obsene price for a transit turbo! 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1071520 15th Jul 2025 7:34pm
As mentioned the factory turbo is Garret, last time I looked they were around £800 - £900.
And that is a lot of money.
I think you can find the model no the casing, so long as that matches you’ll be good to go.
Personally I’d steer well clear of any recon, only go for new.
Just my opinion of course. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071528 15th Jul 2025 9:26pm
Likeomg
Hi,
So any of these 3 would be correct as a new genuine turbo?
I can't check my casing as its got a non standard hybrid on which i want to remove.
(and the fact im overseas)
Post #1071543 16th Jul 2025 6:40am
bear100
i was very lucky and picked up a new old stock unit from Ebay for £250 apart from a some surface rust on the usual parts it was perfect, made a huge difference when fitted too.
took me about 2.5 hours to fit but im quite methodic and fussy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1071546 16th Jul 2025 8:19am
Likeomg wrote:
Hi,
It would appear so, they all have the same SKU.
Post #1071552 16th Jul 2025 9:20am
Likeomg
Any other recommendations for what to change?
Turbo lines
VCV? etc?
Post #1071563 16th Jul 2025 12:34pm
hank
Bit slow on the reply here sorry but yes. OEM unit is Garrett so the JLR one will be Garrett just with the JLR markup on top.
I didn't replace the turbo oil lines when I did mine. Tip - remove the oil return form the block, fit it to turbo beforehand and then "post" the oil return down to the block when fitting the turbo. It is a pig to fit the oil return to the underside of the turbo in-situ and disconnecting from the block only takes a few minutes.
How old is your VCV? For the cost of them and the time it takes to swap out there is certainly no harm in fitting one.
Here is the unit Turbo Technics supplied me
 > 110 XS Double Cab
Post #1071583 16th Jul 2025 5:20pm
Likeomg
Looks good, i've sent them a mail
waiting to hear back
Post #1071584 16th Jul 2025 5:24pm
hank
Edited my post now with more info!! > 110 XS Double Cab
Post #1071586 16th Jul 2025 5:27pm
