![]() | Home > Puma (Tdci) > Overheating in 6th gear going uphill (SOLVED) |
defenderfraggle Member Since: 06 Dec 2022 Location: Leiden Posts: 24 ![]() ![]() ![]() |
In hindsight, perhaps a new/different engine would have been a smart idea. Including the cost I had before the gasket (heat gelaten, but apparently not the cause) it would have costed the same?
I’m happy with the car, if maintained a td4 runs fine. It is also remapped. And as said, gaskets can be done cheaper. My garage is expensive, but the only specialist nearby. Jan |
Pasc1377 Member Since: 14 Jul 2025 Location: Ilmenau Posts: 5 ![]() ![]() |
Yes, a conscientious and trustworthy workshop is worth a lot.
I still haven't fully understood whether it could be the EGR cooler. Did you check this somehow beforehand? |
No, my EGR has been taken out....
Perhaps I should also endeavour to do this. The EGR cooler has then also been completely removed from the cooling circuit, right?
