Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 14 of 14 <123 ... 121314
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Gearbox quantity for the 2.2….
I have always filled with 2.2L on my 2015 vehicle. This is according to the 2011 published service manual from Land Rover (that includes information on the 2.2 and 2.4 engines)
Where are people seeing 2.4 for the quantity?
Post #1034507 12th May 2024 7:33am
Naks
IIRC, 2.4L is for the initial fill, 2.2L for a refill, as you can't get all of the oil out. --
Post #1034508 12th May 2024 7:38am
Yannis
That’s what I thought, but a few pages back people seemed to be using the 2.4L every fill…
Post #1034509 12th May 2024 7:40am
Ianh
For the 2.4 the owners manual states 2.2litres for a drain and refill, however in the 2.2 owners manual it states 2.4litres for the drain and refill. Given it’s the same MT82 gearbox at what I expect is the very same angle for the 2.2 or 2.4 this is a bit of an enigma.
So did LR decide that an additional 200ml was better when they launched the 2.2, or did the authors of the users manual get it wrong on the 2.4 or 2.2 users manual. Who is to know !
From personal experience I was the first to drain my 2.2 gearbox, and because of the above decided to measure the volume of oil that came out. It was 2.4Litres so I put 2.4litres of fresh oil back in. Gear changes have always been easy and smooth before and after oil changes and to date I have not had any leaks.
See page 10 of this same topic
Post #1034524 12th May 2024 11:45am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Just to add a bit of confusion.
Here's a shot of my 2013 owner's manual (2.4L for a refill)
and a screenshot of the 2011 WSM (2.2L for a refill)
I have a feeling it might not really matter.
Post #1034526 12th May 2024 12:01pm
HardCharger
Locally, I found fully synthetic 75W-90 gear oil that meets API GL-5 and MT-1 quality levels and approvals. This good for our differentials and Transfer case?
From same manufacturer, fully synthetic 5W-30 with API CJ-4, ACEA E9 quality levels and approvals. Good for engine?
Ford rated oils are difficult and expensive so I'm trying to find locally available oils to make maintenance easier and cheaper.
By the way, since I'm currently situated in the Asia Pacific region, this being the case, will a 5W-40 engine oil work better for me?
Post #1034586 13th May 2024 3:15am
Ngala
I am now confused.
Why would a 2013’Manual stipulate a 2.4L. From 2011 they made the 2.2 only?
I need to change my 2.4 oil too soon…..😵‍💫
Post #1036200 31st May 2024 7:56pm
Yannis
Product names....?
Castrol EPX 80w90 now Castrol Transmax Axle EPX 80W90?
Motul 300 75W90 now Motul MOTYLGEAR 75W90?
Maybe someone knows if they are just the same product with a different name?
Post #1071344 13th Jul 2025 2:11pm
