Home > Maintenance & Modifications > puma transmission upgrades
Page 3 of 3 <123
Ianh
What’s “plain nasty” Mo ?
Post #1071203 10th Jul 2025 9:21pm
Mo Murphy
The late 2 pin diff. The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #1071209 11th Jul 2025 4:29am
keith wrote:
blackwolf wrote:
Puma 2-pinion front diff is definitely NOT up to the job - just replaced my seized and disintegrated unit with an Ashcroft ATB diff. Details and photos on another thread.
Replacing the diff has improved the gearchange enormously.
Where’s that thread BW?
I cannot easily find whichever thread I was referring to, but the photos of my failed diff appear in the following two (much more recent) threads:
https://www.defender2.net/forum/post909278.html
https://www.defender2.net/forum/post956173.html
Post #1071214 11th Jul 2025 8:16am
I can quite see Blackwolf’s views on the rear driveline affecting gearchange, you can get a lot of slop alone from the rear halfshafts and DM’s, that’s on top of slip from the diff itself and other components.
Rear dampers also are another factor where you get changes in weight distribution during and after load.
In those circumstances you get an on off power delivery during each gear change, as you feel you need to ease off and then back on power after going into gear.
Oils make a difference too, especially if diff oil gets thickened or emulsified, you get more drag and less of a slick ride as well then.
Personally, I’m really happy with Castrol oils, I’ve recently gone all out with a full service with premium Castrol, oils and Castrol grease and I can tell the difference.
Even the Castrol, high temp lithium is nice and slick. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071250 11th Jul 2025 5:41pm
Page 3 of 3 <123
