![]() | Home > Puma (Tdci) > Fascinating set of faults |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204 ![]() ![]() |
Mistakenly let some kids including mine play in my Puma while I was helping at a fete at the weekend.
Symptoms after driving off: 1. Both indicators ‘stuck’ on at the same time, then went off, now fine. 2. Fog light button illuminated, then went off and now doesn’t work. 3. Traction control light illuminated, button now doesn’t do anything. 4. Cruise control no longer works - no lights on the stalk, no response, nothing. Any ideas?! May be just coincidence and nothing to do with the kids. I have a bad battery drain which had almost flattened the battery when I set off to the fete. Cheers! |
Thank you, yes I need to spend a bit of time sorting this
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1343 ![]() ![]() ![]() |
When I got my 110 Td5, the temp sensor would shoot up every time the AC kicked in. Obvious fault (earth) which caused a whole host of other issues. Car ran fine. They all do that said the buyer, nothing to worry about.. I suppose if you never look at your instruments. Still got me a reasons for a discount, so was worth it. Fixed after I sorted out a whole bunch wiring issues that got messed with and needed fixing.
