Home > Puma (Tdci) > Puma Air Conditioning
Polarismd
Good evening,
I have been plagued with blown fuses on my Air Conditioning (Fuse 42). I checked for shorts and there does not appear to be any. It comes and goes. Just now I had the engine off and pressed the Air Con button and the fuse blew after a few seconds.
Does anyone have any suggestions as to what might be causing this?
Could it be the compressor clutch?
Chris
Post #1070775 3rd Jul 2025 5:42pm
Excess load if you can’t see any obvious faults, if there is a ground fault on that circuit, that could increase current draw and keep popping the fuse. (Which is why it can appear as a sporadic fault).
You’d need to use a Multimeter if you can and do some readings, and the wiring schematic will be useful if you can find it, it’ll likely be on here somewhere. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1070787 3rd Jul 2025 6:49pm
Polarismd
Re: Puma Air Conditioning
Polarismd wrote:
Good evening,
Chris
I have decided to replace the compressor. Does anyone know what gasket the manifold to compressor uses? And the torques for same?
Post #1070872 4th Jul 2025 10:14pm
philippr86
Germany
The compressor is engaged and disengaged by a magnetic clutch. So replacing the compressor itself probably help. Check the magnetic clutch and the circuit.
Post #1070977 7th Jul 2025 2:45pm
